Forged Wheels - 1pc vs 3pc (vs 2pc)
I have predominantly have had cars with OEM wheels on them (sole exception was Kinesis K5 on my 993TT as track wheels back in the days...).
As I am looking at different options, I am now getting 'educated' with respect to different features. I used to be able to go with 'cast vs forged' (go w/ forged - stronger...).
So here are my questions to wheel experts out there:
1.) which is the ideal forged wheel if main concern was weight and strength (1pc vs 2pc vs 3pc)? I'm thinking that 1pc forged would be the way to go for a wheel.
2.) I suspect the 3pc are done to make it possible to create different offsets, so is having a 3pc a compromise to make it more flexible?
3.) I know several here love the Champion RG5 wheels. Those are 1 pc forged (and very light). I think they only come with 18x8.5 and 18x11.5 wheels but offset on the rears are 44mm. Is that a big deal?
4.) For those that run 18s, do you run 18x8.5/18x12 or 18x8.5/18x11.5 or do even 18x9/18x12?
Originally Posted by efxautosport1
i think the rear offset is too high for a 996 TT. It should be around et 30
yellowturbo,
Most people change from the stock BBS made wheel not out of necessity but because they want a different look.
I'm no wheel expert, but I can pass along my personal experiences-
-Multi-piece wheels are just as strong as 1pc wheels. They require a little more maintenance, but are easier to fix if damaged. If money is not an object, there are some really light 1pc wheels being produced now$$$$.
- No compromise, 3pc allow you to build a wheel to your exact dimensions.
- Stock offset is 45mm, so 44 is really the same(+1mm). The wheels are 1/2" wider overall or 1/4" on each side. This is probably the widest for stock applications since some cars with 12"'s require fender rolling.
-All these sizes will fit, but I am not sure of any performance advantage for a street car. The wider wheel for these cars usually requires wider tires and possibly some body modifications.
-z
-z
albert@velosdesignwerks
Cayenne
08-28-2015 06:36 PM
Other British Cars
08-22-2015 06:13 PM
Other British Cars
08-20-2015 07:30 AM
BMW //M
08-20-2015 07:12 AM
Cayenne 958
08-19-2015 02:43 PM
