Yokohama ADVAN Neova AD07?
Time for new, OEM sized tires all around. I did a quick search on TireRack.com and these topped the list with gushing reviews, despite treadwear.
http://www.tirerack.com/tires/tires....VAN+Neova+AD07
Any insight?
Is there otherwise a hands-down favourite OEM replacement?
Thanks all
VB...
Any insight?
Thanks all
VB...
Originally Posted by tom kerr
VB, I think the hands down favorite tire for this car is the Michelin Pilot Sport 2, hands down.
After some testing and alot of research on this, I came to the conclusion that the PS2's are the BEST tire for the TT (street use) as long as you have a stiffer aftermarket suspension to make up for the soft sidewalls, actually this will help the handling on the wet BUT if you have the stock suspension or even the RoW suspension (like me) these tires are too soft and the car wallows at high speeds which doesn't happen with Briggestone SO-2A's, Pilot Sport Rib or P-Zeros which were designed with the TT in mind and the PS2's were not, they were designed for the lighter, stiffer GT3.
Originally Posted by BigBadBen
VB....Speed rating is too low for our cars, unless you drive her slowly....MPS2's 315's and 235's.
Unless you plan on exceeding 168 MPH (the Yoko's W speed rating, which is technically higher than a Z rating from earlier days which were 'greater than 149mph') on the street, I'd say they would be just fine.
Of course, I'm with the mindset that the performance envelope of these cars and those tires would be tough to exceed on public roads (or racetracks even, since all tracks I've driven, with the exception of 1, wouldn't get you close to 168mph at the end of the longest straight).
check out the yok A048 they have good grip from cold and grip almost as well as the MPSC's when heated. The advantage for the A048 is good and predictable grip when cold. The auto cross guys seem to prefer them over the MPSC's because they don't have the luxury to heat up the tires. The MPSC's are very dangerous when cold esp after a few heat cycles, have a tendency to go with out any warning.
"Of course, I'm with the mindset that the performance envelope of these cars and those tires would be tough to exceed on public roads (or racetracks even, since all tracks I've driven, with the exception of 1, wouldn't get you close to 168mph at the end of the longest straight)"
Right...would never do such a thing on the street... ....come to BC and drive the mountains with me...that would soon change in a heartbeat...OMG..did I just say that....Me Bad!
The closest I've ever been to the W speed rating limit was probably at Texas Motor Speedway setup with a chicane (ALMS type of setup) after the start/finish line in a stock 993TT-indicated about 160mph before I had to hit the brakes to make it into the chicane...
i have personal experience with these tires as well as the michelin ps2's
they are very evenly matched but surprsingly the advan's have lasted me 8k miles so far and i'm running really aggressive camber. (-3 deg fronts, -2degree rears) car is putting down 450rwhp at low boost pump gas. I've taken this tire on a few track days and even had samuel hubinette (prof drifter / driver ) take the car out and he praised the tires as well.
they are very easy to predict at the limit, and are by far the stickiest street tire i've had a chance to try, you will not be dissapointed with the neova's.
-Curtis
-Curtis
-Curtis
-Curtis
Pacific Northwest = rain. Plus, we live a little higher up in altitude in town, so although we NEVER get to 14F it does get down around 25-30 at the coldest. No tire damage at these temperatures but I am concerned about compromised performance and safety.
Sure as hell is tempting though. If they're OEM on Lotus Elises, they can't be all that radical.
Regards
VB
I run these on my stock 18's when driving on the street. I also have the A048's for the track, but have only taken the car to the track once. I run the Michelin Pilot Sport 2s on my 19's. I also have run everything from Hoosiers, Yokohama A032, A048, Michelin Pilot Sport Cups, Kumho Victoracers and Toyo R1's on my last track car....a 500whp EVO VIII.
The ADVANS compare very favorably to the Michelin Pilot Sport 2s and you will be very happy with them for your 18's. They are predictable at the limit and are very flexible at all temps.
Vanboost - I was hoping you opted for the AD07's as I almost went that way. The saftey factor in cold/wet makes sense, especially so you don't have to worry when your wife's driving the car. I've been driving daily in Edmonton, in the rain @ 2'C-5'C with my new RA1's for the past couple of weeks and they aren't as bad as I had feared. It would be interesting to hear how the AD07s perform is similiar conditions.
socalbreeze
11-14-2015 11:09 AM
socalbreeze
09-11-2015 12:37 AM
