How much HP to the crank can the 996TT run with no additional fuel and engine work?
#32
Originally Posted by Dock (Atlanta)
If you had a 1.1 bar program in your car...a program designed for 93 octane...you wouldn't run 100 octane? I don't see how running 100 octane would be a problem.
Wouldn't it make sense to just have that be a controllable option included in the original ECU flash purchase? What else is different between the different programs except for boost levels?
I read something about a Revo program that has adjustable settings also and I'm trying to get more info on that.
#33
I have an evo8 that runs on differnt boost settings along with my TT but thats being currently finished up and I can't really use it as an example... but the theory will be the same...
YOu tune each boost setting for the appropriate fuel octane... thus a car running only 20 psi on both 93 and 100 octane will never see the gains that I will because my car is tuned for the higher boost/octane level.
so while u are still at 20 psi... u really do not gain the numbers....
here is what I did when we tuned the car on a AWD dynojet .
391 awhp @20 psi
456 awhp@25 psi
565 awhp @30 psi
617 awhp @35 psi
640 awhp @40 psi
I used different fuels for each run...
and to prove my point... check the wheel HP gains some tuners offer with the 100 octane map vs pump... the ratio in HP gains is no where near what I just achieved... why? because they are still at 1.2 bars or less running 100 octane.. just like on pump gas. Granted they adjust timing not to detonate... among other things...
this is my opinion only- I may be way off on this one...?
2001 996TT 3.6L and stock ECU
#34
Originally Posted by yellowturbo
I thought I saw a post here a few weeks ago that indicated some were running as high as 1.5 bar (I think it was GT640 or GT700 cars) - a level that I wouldn't want to be running on pump gas with stock internals.
Do cars with selectable race programs generate more boost (relative to the boost generated with the street program) when these race programs are in use?
#35
Does the GT700 require 100 octane all of the time?
The 2nd question, I will defer to more knowledgeable people .
#36
that is absolutely a mechanical procedure done via vacuum. thats why, for example, evoms is now selling upgraded wastegate springs... 1 bar springs vs. 6 psi bars springs that come standard...
and thats where the "controllable" boost feature comes handy.... its actually controlling the wastegates via vacuum..( pressure).
#37
Originally Posted by MARKSKI
to answer ur second question- no.
Why isn't a higher boost format written into the "race" program? For example, a 1.1 bar 93 octane program, with the selectable race/100 octane program having different timing and higher boost...a "boost controller" but one that is selectable through the key fob controller? Or is that what you mean by a controllable boost feature?
#38
Dock,
"controllable" is meant using a third party electric boost controller(EBC).
My whole point is that most P car tuners simply keep a static boost setting( whatever the wastegates are set up to)... then make program maps for different fuels... From what I understand they use MAF sensing...
The other way to do it.. like my evo and P car... is to do (MAP)pressure sensing where the ecu does not know what FUEL ur running rather then what BOOST ur running... and thats how 99% of stand alone ecus work... AEM, Autroniks, Motec, etc...
By ridding yourself Mass Flow Sensor, this leaves you unrestricted in intake manifold design, and allows calibration on turbocharged engines to compensate for any boost condition.
BTW, Im no tuner nor an expert.. IM just repeating stuff/emails and or conversations I have had with a body of tuners including my current one...
#39
Marski being modest...He 1 of the most knowlegable guys on 6speed and as far as I'm concerned very unbiased. The 1 thing with him is that he's done most of the setups so he knows from experiance....anyway in my conversations with him he's never given me a bad piece of advice...
JB
JB
#40
As usual Markski is spot on. Here is my dyno runs at 1.1 bar. Right around 500-510 RWHP on 91 octane. As you can see, the A/F ratio is spot on with the GIAC K24 software. There is plenty of leeway for adding hybrid turbos etc.. with most software.
I'm now running 1.2 BAR but have yet to dyno.
http://members.dslextreme.com/users/...o/Dyno%20Runs/
To add to what Markski is saying. It seems that the software has little to do with control of boost. Crank the wastegates and get more boost (especially with modified wastegate springs).
#41
JB
JB
#42
Dock,
So if I pick up Kevin's ZC hybrid turbos I should be running them on 1.1 bars if I'm on 91 octance and 1.2-1.3 bars when on 100 octane? I know that I will have make me a 100 octane program, thats for sure. Besides the FPR, I will also be picking up a Greddy or HKS manual boost controller to better dial in the boost and adjust it.
#43
Originally Posted by USCTrojanMan29
Great input again...
#44
Originally Posted by Kevin
Martin, with my programming there is no need to add a Greddy. I have 8 mapping options. I can program a high boost, and low boost low octane file. And I can program a high boost, 100 octane file.. I can program a low boost-bad weather file, Valet, turbo-breakin.. Basically anything that one can imagine.. One of the most frequent questions that I get is, "how much boost" Here is what I have summed up with these cars.. The stock fueling is running at it edge around 1.35 bars.. And when you fix that problem with injectors the power output will exceed the rods and rod bolts in your engine at 1.4-1.5bars.. Running a stock car at 1.4 bars with stock fueling isn't wise..
What do you believe are the advantages to this approach vs the external boost controller? How about the disadvantages? Just trying to get an objective view of the different approaches.
#45
Thanks for the response on disadvantages of an external boost controller- but now I'm curious on whether there are any advantages to an external boost controller?
If it's truly unnecessary, then why do some tuners use them? I thought that having the EBC allowed a different way to create the maps.
