Who Gets Above 1.2 Bar W/ Just Programming and Exhaust?
Was seeing only .9 with my PSI 480 tune and Neil said that was normal. Car ran strong. I did Kevins wastegate adjustment (2 full revolutions clockwise) and was seeing and holding 1.1 bar. Kevin suggested that with temps above 80 degrees I should back it down some and try for a 1.1 spike that held 1.0. I backed off a half turn back counterclockwise and she holds 1.0. Car does run a bit stronger with this wastegate tweak. Not sure if peak power is up but it is a fat strong torque curve that hits early.
PenguiN
09-15-2015 11:44 AM
