torsional rigidity of the 996tt
I think I read somewhere that the 996tt has the highest torsional rigidity of any production sports car. Is this true? I assume that the more torsionally rigid a car is, the better its handling characteristics.
I have a reinfoced Mustang, with a welded roll cage and
welded subframe connectors etc, and when I jack one
end up, it flexes more than the 996tt. I have a stiff suspension
in my 996tt, and if I drive onto a speed bump at an angle, the
opposite front wheel lifts off the ground. This chassis is vey
stiff.
stiff.
You can add the stiffness very easily. Added a TechArt torsion bar between the two shock towers up front. Also added a rear torsion bar in addition to tying the rear shocks together with the roll bar! If I angle down a driveway, the tire will lift.
i have a caged 993TT for ORR, and wonder how else to increase chassis stiffness, will a bar between the shock towers help?
Originally posted by watt
chad et al.,
chad et al.,
definately, it'd be smart to do in the rear as chad mentioned also. Just make sure that they use a strong material.
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
