GT3 sway bars, questions.
Old 11-09-2006 | 02:20 AM
oak's Avatar
oak
if it's clanking you need to either adjust the dl's or the heim joints are shot. get the dl's with the delrin teflon lining.
Old 11-09-2006 | 02:21 AM
oak's Avatar
oak
lI have the GT3 sways front and rear and they are great. you just need to set them up correctly.
Old 11-09-2006 | 02:49 AM
Zippy's Avatar
Originally Posted by oak
snug setting = understeer on turbos unlesss you have more than -2 neg camber. have you tried it? trust me you don't want it tight.
I've tried to counter understeer by going much tigher on the rear SB's in conjunction with 3/4 soft front coils and 3/4 tight rear coils. It actually seems quite balanced.... this is before I went with 245F and 335R Rcompound... not sure until I experiment in the spring.
Old 11-09-2006 | 11:10 AM
sharkster's Avatar
Oak is right.. it doesn't take too much to go from the understeer right into oversteer mode... and that's not really safe or good either.
Old 11-09-2006 | 11:12 AM
sharkster's Avatar
Originally Posted by Zippy
I have the GT3 front and rear SB with ScarGo curved front drop links. I get a bit of clanging up front when going over speed bumps. I believe to have them quiet, they need to be set on the loosest setting. I have no interest in the loosest setting. I like the car 'snug'.
H&R front and rear sway bars - Sharkey, how good are they? 3 setting vs. 5 on the GT3s? Can you snug up the front and the rears even more so and have a 100% clang free ride?
Well Mike, your set up is slightly different to Oak's (coil overs and where the drop links mount) so you do need to be careful. Don't go any further than the middle hole on yours. At least you have some expensive curved drop links.. but anymore than the middle and it'll bind. I honestly prefer the H&R set up on these cars these days but what you have does work and just don't go further than the middle...
Old 11-09-2006 | 04:14 PM
SDEVILTT's Avatar
SDEVILTT is infamous around these parts
Alex are you saying that the the H&Rs are better no matter what? Could I use GT3 if I had custom end links made? Or should I just use H&R? If H&R, which set should I order if I am going to do the RWD conversion? Joe
Old 11-09-2006 | 04:24 PM
iLLM3's Avatar
Originally Posted by sharkster
Well I don't like the idea of GT3 sway bars on a AWD or even RWD TT. Unless you change the wheel carriers/hubs etc... then the geometry is all wrong and you have binding issues with drop links etc.. Not a good match really. Stick to a set of H&R ones that are made for a turbo instead of a 2WD car like the GT3 or GT2.
Alex the GT3 sways you sent me are fine on my turbo even with stock droplinks, although you hear them clunk sometimes over a big bump or at full lock you can hear them, they will be swapped out soon but not bad! Totally changed the feel of the car
Old 11-09-2006 | 11:55 PM
Zippy's Avatar
Thanks Alex
Old 11-10-2006 | 03:37 AM
sharkster's Avatar
If you have custom drop links made then you're likely going to be ok... I guess what I am saying is it depends on what you want. If you want to play with understeer/oversteer charachteristics and want to spend 300-400 on noisier custom drop links then the GT3s are fine. If you want something that's "beefier" and catered more towards say changing lanes quickly with less sway then the H&Rs do a fine job.
Old 11-10-2006 | 06:11 AM
oak's Avatar
oak
honestly, save your money and just leave it alone.
Old 11-10-2006 | 10:52 AM
sharkster's Avatar
hahah that's my line. And Porsche knows best..... leave it BONE STOCK
04-28-2022 01:38 AM
orbelo
08-30-2015 01:26 PM
LiquidElephant
08-27-2015 07:17 PM
TrackOne
08-20-2015 01:56 PM
