GT3 sway bars, questions.
Old 11-07-2006 | 11:48 AM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
I am thinking of adding these. My car will be converted to rwd so Ive heard I could also use the front sway. I currently have ROW suspension and stage 2 power. What could I expect from putting the sways on and should I do both of them or just the rear? My car feels pretty sloppy and motorboat like at times now. I cant afford coilovers though so I will need to keep the ROW stuff for a while. Does anyone have both front and rears here? thx
Old 11-07-2006 | 01:42 PM
sharkster's Avatar
Well I don't like the idea of GT3 sway bars on a AWD or even RWD TT. Unless you change the wheel carriers/hubs etc... then the geometry is all wrong and you have binding issues with drop links etc.. Not a good match really. Stick to a set of H&R ones that are made for a turbo instead of a 2WD car like the GT3 or GT2.
Old 11-07-2006 | 02:50 PM
rwm514's Avatar
Really? Wow I thought I read here before that it is a great, cheap mod. Hmm
Old 11-07-2006 | 03:43 PM
kiko's Avatar
kiko is infamous around these parts
Yes, but its only the rear GT3/GT2 sway bar. IMHO its all you need and its cheap and effective.
Old 11-07-2006 | 03:52 PM
rwm514's Avatar
Are the H+R sways more expensive?
Old 11-07-2006 | 03:56 PM
sharkster's Avatar
Not really no. They're beefier too...
sharkster's Avatar
The rear one is fine. The front one is the problem correct.
Old 11-08-2006 | 01:26 AM
03-turbo911's Avatar
Senior Member
Not if he's yanking that front diff off.
Old 11-08-2006 | 09:09 AM
rwm514's Avatar
Would it be OK to just run the rear bar if I have RWD or should I do both?
Old 11-08-2006 | 09:34 AM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
I'm w/ Sharkster - went w/ H&R all the way - made a big difference and not that expensive. Also have PSS9s in the set-up too. Very nice on the street and made a big improvement on the track.
Old 11-08-2006 | 12:00 PM
sharkster's Avatar
Michael that's the set up to have. Perfect combo everytime
Old 11-08-2006 | 12:01 PM
sharkster's Avatar
It still is a problem unless he changes the wheel carriers/hubs etc... the geometry doesn't change when you pull a differential
Old 11-08-2006 | 01:56 PM
That damn geometry - was a pain in 8th grade too !!!
I think Racersgroup had some special drop links to buy to then use the GT2 bars on a tt - not sure about that, by the time you got all that stuff bought and strapped on it cost more money and probably weighed more too - IMHO.
I would still recommend the H&R for the tt - I have had to problems w/ quality or installation - heck Sharkster says OK and I think he's seen quite a few set ups.
BTW I did use the GT3 bars on my 2001 996 and that worked great - of course that is 2WD apples vs apples.
Old 11-08-2006 | 11:11 PM
Zippy's Avatar
I have the GT3 front and rear SB with ScarGo curved front drop links. I get a bit of clanging up front when going over speed bumps. I believe to have them quiet, they need to be set on the loosest setting. I have no interest in the loosest setting. I like the car 'snug'.
H&R front and rear sway bars - Sharkey, how good are they? 3 setting vs. 5 on the GT3s? Can you snug up the front and the rears even more so and have a 100% clang free ride?
Old 11-09-2006 | 02:18 AM
oak's Avatar
oak
snug setting = understeer on turbos unlesss you have more than -2 neg camber. have you tried it? trust me you don't want it tight.
