New Mod Completed - What you think?
Old 11-14-2006, 02:21 PM
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by rwm514
Holy Moses! Im calculating 657 torque and 546 bhp. Can you really be making that much torque on k-16's?? Im assuming your curves were the solid lines and the gt640 was the dotted, correct?
Actually 455hp/548tq with a 20% loss is 568HP/685TQ crank. 455/.8 and 548/.8 Kevin
  #47
Old 11-14-2006, 03:16 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
I thought it was 455 x 1.2 and 548 x 1.2??
  #48
Old 11-14-2006, 03:20 PM
rwm514's Avatar
Originally Posted by vividracing
Hi, I had a great time working and brainstorming on the project. I should have the new file ready for upload this week. The Dip in the power is the pesky Drive by wire throttle control closing the throttle down as maximums are being reached in the ecu maps. We should have this issue fixed and the maps rescaled shortly. Its part of RD on making power like this. Its a challenge but I am up to the task. To get us this far I have placed a Diode on the MAP sensor to trick the ecu into thinking its only seeing 1.0 bar instead of the 1.2-1.3 the car is producing. Its an old trick I used for years. Obviously I cant suggest out customers do this as it removes safety features and it makes the in car Boost gauge read 1.0 max. However, It was a part of RD to disable these systems in a closed environment. The true fix is to hit the keyboard and program this out which will be completed soon.
If anyone has a question I am here to help.
Clark Turner
Clark, I thought the k-16 lose efficiency at anything over 1.0 bar. Do the external wastegates make the turbos more efficient? Also, could you predict the hp and TQ with k-24's? Have you guys finished to k24 car yet? Cool stuff!
  #49
Old 11-14-2006, 03:21 PM
KPG's Avatar
KPG
KPG is offline
Depends on what you are looking for. Do you want crank HP- loss factor or AWHP + loss factor. Two very different numbers. Stephen at IA chimed in on this before AWHP/(1-loss factor)=FWHP Kevin
  #50
Old 11-14-2006, 03:23 PM
rwm514's Avatar
KPG, could you estimate the trap speed of this car and maybe 60-130. thx
  #51
Old 11-14-2006, 03:30 PM
KPG's Avatar
KPG
KPG is offline
If it weighs as much as my tank(3760), I mean TT I would guess a 124-125 trap. ET..who knows, much too driver dependent. 60-130 would be high 8sec maybe low 9sec with 2 shifts, much less with one. Kevin
  #52
Old 11-14-2006, 04:13 PM
CSudhoff's Avatar
CSudhoff is infamous around these parts
nice setup, what spring are you using on the Tial 38mm?
  #53
Old 11-14-2006, 05:39 PM
vividracing's Avatar
If I am driving it it may trap at 70mph
The wastegate has 2 springs inside.
  #54
Old 11-14-2006, 06:56 PM
SMR's Avatar
SMR
SMR is offline
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
Or buy Kevins uppgrded spring kit or EVO kit for alot less and get the same result
  #55
Old 11-14-2006, 07:01 PM
SMR, I guess you dont understand the concept. By removing the factory internal wastegates, you are increasing exhaust flow. Putting in a new spring in the stock or aftermarket internal wastegates will not produce the same results.
  #56
Old 11-14-2006, 07:22 PM
Rambino's Avatar
Rambino is infamous around these parts
WHat about the EVO Wastegates? are those going to do the same?
  #57
Old 11-14-2006, 07:25 PM
unfortunately they will not. They are internal wastegates that simply take give them a 1.0 bar of boost. Still using the same path of exhaust flow which is restrictive. These are great to replace your factory ones to get more boost, but are a different product then what we have.
  #58
Old 11-14-2006, 07:32 PM
These are the Ultimate wastegates your referring too. Looks awesome and does the job for what they are accomplishing, but again does a different trick then the external. These are super clean though!
  #59
Old 11-14-2006, 07:34 PM
SMR's Avatar
SMR
SMR is offline
Then you need to lear how this thing work..
When the WG are closed all exhoust gased are hitting the turbine wheel, so there are never going to give you anymore HP with a differnt WG, but the stock wg ar to weak so the blow up from the backpresure, and then you will have some exhousts that escapte that way, and you lose some performance..
  #60
Old 11-14-2006, 07:37 PM
SMR's Avatar
SMR
SMR is offline
You are not removing it, you are just closing it with a rod, same as very stiff spring and realising at diffrent posistion
Quick Reply: New Mod Completed - What you think?
