New Mod Completed - What you think?
Old 11-09-2006, 03:25 PM
vividracing's Avatar
We were trying to think of some different ways to gain HP over the traditional methods. One thing we have done on some of our STI and EVO cars we have built is to close the factory internal wastegate and run an external Tial 38mm wastegate. Why do this? The factory wastegate is restrictive and the flow of air is not able to be maximized. When you start increasing boost and going for more power, you can gain more HP by going to an external setup. As tested and proven on other cars, the external wastegate setup made 20-30HP on the dyno to the wheels So.... Why the hell not right.
To prototype this setup for Agency Power, we took a set of headers from GHL, 2 Tial 38mm wastegates with 1.0bar springs, and connected the dots. With a quick fab job, we attached the necessary vacuum lines and throw it on the dyno . Before running the car we reset the ECU and then went for it.
What went right and what did not... The car was only making about 12psi so the spring in the wastegate was to soft. Even though it was a 1bar spring, it was making a little less which is about normal. so we have a new spring coming tomorrow. We threw a manual boost controller on the car, but because the ECU was noticing more air being introduced, it would close the throttle plate. So the good thing is that on 12PSI 2 PSI less then our before dyno, we made the same HP and TQ about. 450 and 490. So once we have the new spring in and make about 1.0-1.2 bar. We should be making that extra 20-30WHP that external gates create. Another cool thing about this setup is the boost is almost instant, takes away some lag and really makes for a fun car to drive. Because of the difference in pressure, the AP BOV is much louder.
So sound clips, new dyno charts, and info are all coming soon. Here are some pics. More pics can be found at www.myvividracing.com/gallery
The production model will be very similar. Should cost around $1995. For 20-30HP, not bad
Old 11-09-2006, 03:53 PM
iLLM3's Avatar
Very interesting
Old 11-09-2006, 03:55 PM
Looks good
I have a similar approach... tial 44 mm Wgs....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 11-09-2006, 03:58 PM
LOL, yeah i could unbolt and put the 44mm on their New springs come tomorrow, we will see. Best part about it is they fit the same and can be targeted towards different HP customers. Wait till you see the video clip and see the dyno!
Old 11-09-2006, 06:51 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
What would be the benifit of the mod to my car? GT700
Old 11-09-2006, 06:54 PM
you have a GT700...rad! call me and we can discuss what would be best for you
Old 11-09-2006, 06:56 PM
jags911tt's Avatar
Can you tell me now
Jag
Old 11-09-2006, 06:58 PM
sharkster's Avatar
Jags, I would assume you would need to be retuned for external waste gates tho?
Old 11-09-2006, 07:03 PM
jags911tt's Avatar
Well forget that then.
Cheers Geeza
Old 11-09-2006, 07:05 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
Cant wait to see how this does with the new springs. Great idea.
Old 11-09-2006, 07:08 PM
No problem will post results as soon as possible. As far as the GT700, I am not familiar with that setup. However at the level we are at, retuning is not necessary.
Old 11-09-2006, 07:13 PM
jags911tt's Avatar
Thanks Dan. When should I expect the BOV?
Old 11-09-2006, 07:16 PM
sharkster's Avatar
Cheers Geeza
No worries Jags, I know you have the GT700 so messin' about with it can seem like fun but it's a delicate balance. The main difference is in the way that GIAC or Kevin etc... does their tuning for boost control etc.. and they rely on the factory-style-internal waste gates. Protomotive for example uses external and tunes that way.
Old 11-09-2006, 07:22 PM
JWC's Avatar
JWC
JWC is offline
JWC is infamous around these parts
I like people who think outside the "box". If we all copy and do the same things we all get the same results. Sometimes different IS better.
Old 11-09-2006, 07:28 PM
Thanks for the support!
Quick Reply: New Mod Completed - What you think?
