Who Does the BEST ECU Remapping - Opinions and Sales Pitches Welcome
Old 11-14-2006, 04:58 PM
Zippy's Avatar
Originally Posted by KPG
Well, I guess you are wrong. Kevin
Care to explain? I wasn't aware your file was TUNED/CREATED on your car. Sure, you have some customized options applied to a genaric file (as do I), but neither of us have a custom tune.
  #32
Old 11-14-2006, 05:05 PM
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by Zippy
Care to explain?
What would you like me to do with my programming to define "custom". I can call Kevin today and say..I have too much wheel spin below 3K rpm, get rid of it. He would send my programmer back the next day, and the car wouldnt be able to get out of its own way under 3K. My wife doesnt like the mid range punch... fine, send it back and lowered mid range TQ. You know Kevin I am starting to get concerned about my rods...lets lower peak TQ across the board 10% but take 20% out at 5K rpm just for good measure. Kevin, my Durametric is telling me the car is too rich...lean it out a bit.Fine. All I have to do is send my programmer back and he will do it... free. Anything else? Kevin
  #33
Old 11-14-2006, 05:07 PM
KPG's Avatar
KPG
KPG is offline
Every file starts with a generic file.... is a custom built house not custom because it has a foundation like every other home?
  #34
Old 11-14-2006, 05:14 PM
Zippy's Avatar
Don't get me wrong. I am considering blowing out my GT700 kit and switching to Kevin's stage 3 or something from Protomotive if Garrett @ GIAC can't get this MAF thing figured out. I like Kevin.
Out of repect to him, I'm not going any further with this.
  #35
Old 11-14-2006, 05:20 PM
KPG's Avatar
KPG
KPG is offline
No problem...just a difference of opinion. Take care ,Kevin
  #36
Old 11-14-2006, 05:21 PM
WOODTSTER's Avatar
I have nothing further to add, your honor...
  #37
Old 11-14-2006, 05:24 PM
Zippy's Avatar
I agree. Symantics.
  #38
Old 11-14-2006, 05:30 PM
yellowturbo's Avatar
yellowturbo is infamous around these parts
Definitely 'custom' to what you are looking for, but not in the strict sense of actually tuning the car on a dyno as the changes are being made.
Now what would be cool is if a tuner can do some remote tuning - i.e. have the car at a dyno, make the changes (perhaps through remote download) based on the results of whatever meters are attached (AFR, boost, TQ, HP, etc.), and then re-dyno. Of course, it would also be great if the fuel type was a known quantity (was pump gas REALLY 93 octane?..). Then again, all that trouble may not be worth the incremental improvements you may gain.
  #39
Old 11-14-2006, 05:32 PM
KPG's Avatar
KPG
KPG is offline
The only truly custom file is Markski's. Todd writing a ground up file on a GT3 ECU and writing ABS and PSM in to use on a 996TT is the definition of custom... Not my style though, would you really want 1200HP.. Yes...Kevin
  #40
Old 11-14-2006, 07:13 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
What do you call a file that is extracted from your ECU, e-mailed to Germany, the values of the file are then deciphered and the ECU is remapped based on the values of the original program. Is this not a "custom" program written based on your particular ECU map values? Aren't most of the other programs just generic maps that over write your original program?
  #41
Old 11-14-2006, 09:35 PM
KPG's Avatar
KPG
KPG is offline
GIAC uses multipliers off the stock code I believe. Most of the Euro tuners use Bosch code. I think . Kevin
  #42
Old 11-16-2006, 02:56 AM
Turbo Fanatic's Avatar
Another thumbs up to Speed Gallery.
Depends how crazy you want to get. I chose an X50 and am very happy with the simple flash and bolt on results.
GIAC K24 Flash, Exhaust, EVO Intake, DV, Modified wastegate springs and driveshaft removal. Nothing more or less and I'm pumping 500-520 at the wheels on 91. That's very close to 600 HP and enough to keep the tires fighting for grip. I really don't know if I want any more. It's already too fast for the steet IMO.
For me, and the goal is different for everyone, the car is close enough to stock that it runs well and in case of problems is a (back to stock) flash away from not losing the extended warranty.
Markski: While I agree with you on 99% of topics. I woudl have to say that off the shelf flashes are designed for simple uprades and work admirably at the intended purpose on 99% of cars. Most have enough latidude to safely adjust for quicker spooling turbos and even upgraded turbos (just run K24 flash for modded or hybrid turbos of similar size) while maintaining a good safety margin. When you start to step away from the usual mods, then you may need custom tuning.
KPG: do you have a dyno to share?
  #43
Old 11-16-2006, 12:43 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
I would like to see KPG dyno sheet too...
  #44
Old 11-16-2006, 01:22 PM
KPG's Avatar
KPG
KPG is offline
Sure..been posted for quite some time.. Kevin
ARI...Ummm, you posted on my dyno thread
https://www.6speedonline.com/forums/...ad.php?t=62092
  #45
Old 11-16-2006, 06:42 PM
g8rbob's Avatar
g8rbob is infamous around these parts
Wow 44 replies and over 1200 views - but I got to say - I was hoping for - More along the lines of:
EVO this . . . GIAC That . . . . REVO the Other . . . . GMPperformance, RUF, AWE, Powerchip, FVD, Sharkwerks, DNA, Imagine, VF, GMG, Powertech, ACR, . . . etc . . . etc. . . . etc.
I am not feeling very much smarter . . . YET?
By the way, I am strictly a daily driver / Frequent agressive track day user. No street Drags. No 1/4 mile runs.
Quick Reply: Who Does the BEST ECU Remapping - Opinions and Sales Pitches Welcome
