Enco Exclusive Turbo/GT2 - In Dubai
#32
Originally Posted by MARKSKI
thats what I said too?
#34
Originally Posted by deputydog95
i guess money can't buy taste yeck. red carbon fiber?? what is the deal with the roof scoop on the red one? is doesn't even appear to functional....
#36
Too RICE for me
Looks like a Porsche mated with a beluga whale. Must have been one hell of a party at Sea World . one question? I wonder how much booze it takes to get a beluga whale drunk?
#37
Originally Posted by woolyg
Are you kidding me? If you could buy yellow carbon you would have all over your car... wouldn't he Luis??
#40
so it's working like a pressurized airbox on a motorcycle then?
if the ducting from the hump is going to straight to the turbos, then why does the car still have the stock airbox? also, it apprears from the pic that the outlet on the turbo that should be connected to the intercooler is not connected. what is the blue pipe in the middle for? this is a confusing setup....
also, how could the hump on the red car possibly be functional? it looks too flat compared to the grey car.
I believe that the airbox is not doing anything there, but if this is the case, they must have some sort of MAP sensor fitted somewhere on the manifold through which they calibrate the (modified) ECU readings....Also check out the blue hose going straight into the throttle body, all of this coming through the box inside the car that is in turn getting fresh air from the horrible intake on the roof. The red car is for show.
I am not a mechanic but this is what it looks like to me.
#45
Originally Posted by Jean
I am not sure what the exact setup is, but I have seen the same thing elsewhere. On the silver car you can clearly see that the 2 orange pipes coming from inside the car are going straight into the turbo inlets, I initially thought they were channeling more air into the intercoolers. 9FF uses a similar setup as well on some of their engines.
