Impressions of my new mods.
Originally Posted by rwm514
Thx for your input. I think vivid was trying to get me a good setup for as low a price as possible which I appreciated. Im not worried though, they are stand up guys and going to take care of me if this clutch doesnt improve.
Yeah, the streetability is terrible right now. Spec advises to rebleed it so we will see if that helps. I feel like I need a pit crew to push me from every stop .
Does your clutch also engage very hi up?
I havent got chatter but a strange new noise.
Originally Posted by Nate@EVO
Typically the clutch will not improve if it is already hard to operate. We have a slave cylinder upgrade that will improve the pedal feel thus reducing the touchy engagement point that you are feeling. The OEM sachs motorsport clutch kits are ideal for your power level.
I havent got chatter but a strange new noise.[/quote]
Yea the pick point is very small and very high. The exact opposit of my other car with a manual. Like the other guys said the Sachs set-up is the way to go.
Did you have any problems with the pilot bearing being loose in the flywheel? I had to get the guys at SPEC to install it because the original flywheel that was supplied the bearing just fell through the hole. Normally they are to be pressed in. Maybe this is part of the awfull noise it makes?
Are you guys sure all that harmonic and vibration is not bad for the trans or driveline??? It scares me to be honest.
Gunther- How is the green zone over in Iraq?
stay safe.
markski
stay safe.
markski
2001 996TT 3.6L and stock ECU
Originally Posted by joetwint
Take this car to Evoms.I have the same clutch and hated it.They have the fix for this clutch.It is superb with better feel than stock!The car will almost roll away from idle.I love this clutch now and used it all day at the Scottsdale drags and never stalled.Call them you'll love it!
Originally Posted by melsta
how come i dont see the slave cylinder upgrade on your site does it come with any of the clutch kit that you guys have? how much for that slave upgrade?
SMR, if you sell products, have some respect for others business. I laugh everytime you say the Big Boys...apparently you dont know anything about us. If you want to bash, have a pair and call me on the phone at least.
Rob and I talk all the time on email, so we can help out the situation. The Spec Clutch was in anticipation of going for 600+ WHP so it is a real strong race clutch.
Thanks for your input Nate. Spec says they design their clutches to release high. They also recommended a rebleed and that the clutch pedal will drop down once broken in. Either way, if it sucks and you hate, we will take it out and switch it out no problemo....
I do not se you as the big tuners in the US i se Vivid as small compnay that try to sell cheap things and try to sell there pars no matter what
If that is the same clutch that Joe has on his EVOMS GT800 it is very strong.
And, with the modified GT2 slave cylinder Joe said it drives beautifully!
Maybe take it to EVOMS (nothing against Vivid), and have it rectified.
MK
MK
