need new battery
Old 12-06-2006 | 07:38 PM
JWC's Avatar
JWC
JWC is infamous around these parts
need new battery
I need a new battery for my 02 TT. I am thinking about the Optima. What size / model do I need? Thanks, John
PS Yes I did the search thing, read quite a few pages but can't figure out what size /part number I need.
Old 12-06-2006 | 11:13 PM
SallyMobile's Avatar
SallyMobile is a jewel in the roughSallyMobile is a jewel in the roughSallyMobile is a jewel in the rough
Old 12-06-2006 | 11:30 PM
JWC's Avatar
JWC
Thanks. I checked the link and it tells you how to install the battery but not which battery to install. I need the size info.
Old 12-07-2006 | 12:31 AM
34r is the most commonly used, I believe.
Old 12-07-2006 | 07:13 AM
JWC's Avatar
JWC
Thank you very much.
Old 12-07-2006 | 09:14 AM
tom kerr's Avatar
optima red top if you dont want to save weight
this if you do!!
Old 12-07-2006 | 04:24 PM
this if you do!!
I used one of those on my other car. They're nice and light.
With the 911, I went with this one for slightly longer life:
http://www.tempestbatteries.com/html/bab26-12.html
To 10.5 volts, the Odyssey PC680 is rated at 15.4 Amp Hours. This one is rated at 36 Amp Hours, more than 2x the capacity:
It weighs 14.99 lbs too, exactly the same as the PC680.
Old 12-07-2006 | 05:05 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
What does the additional amperage do? Does that make it last longer? Please forgive my ignorance, I know nothing about batteries? Did you order the Tempest online?
Thanks,
Adam
Old 12-07-2006 | 06:01 PM
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
I have the next step up from toms odysey! I'm in NY need more cranking
power & still saved 25 lb!
Old 12-07-2006 | 08:14 PM
Thanks,
Adam
Yeah, I got it from their online distributor. The link is on their website. I used the Odyssey SAE posts (about $11 shipped), but there are probably cheaper and easier choices at your local auto parts store.
The additional amp hours allows the vehicle to sit longer between drives without a battery tender. At 14.99 lbs and 36 Ah to 10.5v, it's actually reasonably good considering the competition. For instance, the bigger Odyssey PC925 battery at 26.0 lbs is rated at 26 Ah to 10.5v. To get more Ah out of an Odyssey, you'd need to step up to the PC1200 at 38.2 lbs and 39.5 Ah.
Old 12-07-2006 | 08:44 PM
JWC's Avatar
JWC
Thanks guys I went with the Optima D34 Yellow top. I used my motorcycle battery tender attached to the battery leads to keep from having to get radio codes.
adnanm3
10-25-2016 08:38 AM
airbusdrvr
12-27-2015 07:43 PM
WheelsupZR1
10-20-2015 08:36 PM
G ///Mcgregor K
09-30-2015 01:46 PM
Quick Reply: need new battery
