Project of the year!
#228
Originally Posted by robmd99
Ok Chris... I Will Be There!!!!!!! I Will Bring 500 Dollars Just In Case Your Friend Desires Cash??? Hell I Gave Momentum Over 3 Grand In Two Weeks
#229
can he check the ecu as well???? just in case it was fried?? did they hook up my battery cables backwards??? did they forget to tighten down a hose?? did they forget put my sparkplugs back in LOL?? or did they just **** in my gas tank after Stephen chewed on the asssss????????
#233
Brother's is the BOMB if you like NYC style. Nothing else here touches it. Classic's Pizza has the best "gourmet" pizza with Extreme Pizza close behind in 2nd.
We have to take the car to the dealership to scan it.
#234
I would start by looking at the whole Throttle body assembly. All that had to come out when they did the alternator. Why they were messing wiht hte fuel lines while doing that job is beyond me as as well. So who knows what the hell has been messed up. The TB adapter is silicone on one side and screwed in on the other. So if this wasn't sealed back up it is pulling air around the MAF as well as causing a boost leak. This should be checked. They would have removed the hoses as well. So check that.
Limp mode has occurred and we need to know why. Are there any CELs? It could be gas, caused knock and closed the TB. However so much was messed with after it left here and they were uncertain of anything lord knows what is out of kilter now. When the car left it was cutting the tires loose at 80MPH and hitting 1.4 bar in a blink of an eye.
I would also make sure you are in pump mode.
#235
thanks stephen i am on my way to chris... put in some new gas... wish me luck!!!!!! maybe you can come next weekend?? if so i will leave it at autodynamica.. they are an evoms distrubutor
robert
robert
#236
We didn't troubleshoot the oil pressure gauge problem. We decided it is definitely not actually having low oil pressure. Next week we'll get it scanned and determine if it is the sender or the gauge.
#237
Chris MJ and everone else I wanted to say thanks for a great night out... and the 9ff exhaust was fun to put in!!!!!!!!!!!!!!!! and even better to listen to ... hmmm can wait for the next project
robert
robert
