LIFE @ 8200 RPMS (video)
#47
Originally Posted by MARKSKI
I know thats next.... but I have to see how it runs in plus 60 degree temps...
Im on MPSCs now but it in the high 30s to low 40s... no way in hell can I get traction...
markski
markski
Ask Big Bad Ben, he installed the gears I recommended which were also the ones I currently use. Ben has alot of power but not the redline you have. Anyway, whatever you choose, have fun and be safe.
#48
Craig,
thanks for the heads up.
Chad,
I know i know... $11 K for a tranny....
Joe,
Im scared going that far as is... so Ill just keep my 8K .. lol
Chad,
Joe,
2001 996TT 3.6L and stock ECU
#52
That thing builds up revs in third faster than my car in first!
Re. gearing...IMHO don't do anything to it Mark, stock gears are fantastic, just fit slightly taller tires (335s) and you are set... never go the shorter gearing route with a highly modded turbo!! A very tall (over 60+mph at 7K RPMs) first gear is a nightmare to drive on the street, ask me how I know.
Looking forward to see more
#55
Originally Posted by WOODTSTER
BigBadBen or CJV if you know (O.T.)
what speed would BBB gears do in first second, third @7000 rpm??
MK
MK
I would need to know BBB's rear tire size first.
My first gear is a 3.167-1. With a 25.4" OD tires it would be just a tad under 50 mph @ 7000 rpm's. My second is a 1.738-1 with the same OD tires it attains approx. 79 mph @ 7000 rpm's. My third gear is a 1.508-1. With the same OD tires it would attain approx. 112 mph @ 7000 rpm's.
I understand Ben used the same first and second gear ratios. I believe he used different ratios after that. My motor is designed to redline @ 9500.
#57
Met up with Mark today for a ride, and HOLY $HIT, the car is INSANE! Funny part is, he was running it on the lowest boost setting possible (0.8 bar) and it was breaking the tires loose in 3rd gear. And the sound! WOW....it is truly crazy! Inside the car, I think the turbos and BOV are louder than the exhaust. I really have no words to describe this car....but I guess it would be a combination of fast, scary, violent, insane, and any other similar combination you can think of! Can't wait to take it out on full boost!
-Awais
-Awais
#58
-Awais
-Awais
#60
Originally Posted by iLLM3
I am so damm jealous and i hate you
-Awais
