Ruf RT12, LP 640, Saleen S7 and SLR
Originally Posted by AdamT
The ruf time on your list was made on an unused road near pfaffenhausen which i use often (my 16 year old brother is using it to learn how to drive the r turbo on it) which is not the best of surface, i.e a bit broken and crappy.
Also how many of the cars on the list use drag radials? Im sure that would make a difference for the time (not sure of the trap speed though-please advise?)
I think 1/4 mile trap speeds are interesting but its not the end of the story. For instance trap speed wont ever say if a car will run at 200mph all day long, which a ruf will (believe me i know) that cant be said for every modded car.
just my two penneth (or cents )
all the best
adam
all the best
adam
Many of the cars on that list were running on crappy tracks, in hot and humid weather conditions which slowed them down as well.
As far as reliability, we just don't have any place in the US where we can run 200 MPH all day. Do I think the cars could handle it? Absolutely. I do not think RUF cools there cars any better or uses better materials when they build their engines. But there's really no way to prove it without taking an US tuned car to Germany and running the Autobahn for a few months.
Believe me, Adam....I have much respect for RUF cars. MUCH respect. But they do not deny physics, and they are no faster in any situation than other cars of the same weight, HP and TQ.
Originally Posted by brn-997tt
The huge advantage to the RT12 is that the car has great traction on the street without slicks and will run the same numbers it runs on the track on the street with street tires, most of the cars mentioned above must be running DR drag radials and have much better 60fts.
Here...to remove traction from equation entirely, I'll post the list in order of Trap Speed. Remember...Trap Speed is derived from power and weight. As you can see from the below list, many of the cars that have high Trap Speeds have relatively poor E.T's, thus showing what these cars are capable of doing from a roll....when traction is not an issue.
11.09 @ 140.0 - EVOMS 800+ HP TT (AWD at time of run)
11.10 @ 138.1 - DMK / EVOMS 800 HP TT (RWD)
10.59 @ 137.6 - Joetwint / EVOMS 800 HP TT (AWD)
10.76 @ 136.5 - Sharky / Sharkwerks 800 HP TT (AWD)
10.86 @ 136.0 - Divexxtreme / Protomotive 675 HP TT (RWD)
10.88 @ 134.7 - Joetwint / EVOMS 700 HP TT (AWD)
11.32 @ 134.3 - RennTechV12 / EVOMS 700HP TT (AWD)
10.98 @ 134.0 - Cgmeredithjr / Imagine Auto 700 HP GT2
11.0x @ 133.9 - RUF RT-12 650 HP TT (RWD)
11.01 @ 133.8 - Excellence Magazine / EVOMS 700HP TT (AWD)
10.92 @ 133.7 - RenntechV12 / EVOMS 700 HP GT2
11.36 @ 132.0 - BuddyG / Stage 5 650 HP TT (AWD)
10.74 @ 131.7 - Hamann7 / Protomotive 675 HP TT (AWD)
11.21 @ 131.1 - VRAlexander / S Car Go 650 HP TT (AWD)
11.1x @ 130.1 - Roock RST 650 HP TT (AWD)
The ruf time on your list was made on an unused road near pfaffenhausen which i use often which is not the best of surface, i.e a bit broken and crappy.
This has been discussed xx times before.
Below is a picture I took from when Road & Track drove the car.
As you can see this is an unusued piece of road, far from perfect conditions.
And the tires are normal Pirelli street tires.
The car is 100% the same as if you would use it to commute to work.
The car was RWD in this case, but the time above is an AWD time.
However the 0-200 km/h times are similar, but the RWD seems to be even faster.
0-200 km/h
Rt12 RWD (R&T) 9,7 s
Rt12 AWD (Autobild) 9,85 s
I have made a really nice pdf for you, for comparison, but it seems the database is having some issues.
Again...great car and very fast...but no faster than most of the 650-700 HP cars on this forum.
I think some of you believe I'm underestimating the RT-12. I'm not. What I think is actually happening is that you RUF owners are underestimating some of the cars on this forum.
Originally Posted by Divexxtreme
Negative. Most are running street tires. With the exact same tires.
I've been thru a few of the fast cars on the list and I find no info at all about what tires they used.
But they seem to have on thing in common, they all run on dragstrips, not roads. (which is understandeable, but I would certainly prefer to run on a dragstrip with trackbite than on a public road if I was to set a low time. Regardless wether I had RWD or AWD.)
Well, at least the Rt12 is the fastest 650 hp car on the list
Under known conditions.
Erik - According to the magazine that tested it, the time is I have listed is a RWD time. I made sure to carefully check this before I listed it as RWD.
R&T drove a RWD car, but never up to 300 km/h. (well actually they drove 349,x km/h / 217 mph before they ran out of Autobahn, but acceleration wasn't measured then).
That car is in the official list here: https://www.6speedonline.com/forums/...ad.php?t=55163
AutoBild drove an AWD. That is the car in the first post in this thread.
ManufacturerRUF RUF ModelRt 12 2WDRt 12 4WDTested byR & TAuto BildPower650 PS650 PS
0 - 100 km/h3,3 s3,47 s
0 - 150 km/h
0 - 160 km/h6,75 s
0 - 200 km/h9,7 s 9,85 s
0 - 250 km/h15,44 s
0 - 280 km/h
0 - 300 km/h 24,86 s
0 - 402 m11,0 s11,15 s0 - 1000 m19,75 s
EDIT: Sorry my graph didn't come out as expected. I wish I can post my pdf soon.
I understand that AutoBild drove on an old airfield, with less than perfect conditions. Can someone confirm?
Really? Is there any way to tell which cars did and not for someone who does not have inside info?
Again, the Trap Speed list is what really matters here. And the type of tires do not have a measurable effect.
But they seem to have on thing in common, they all run on dragstrips, not roads (which is understandeable, but I would certainly prefer to run on a dragstrip with trackbite than on a public road if I was to set a low time. Regardless wether I had RWD or AWD.)
Well, at least the RT12 is the fastest 650 hp car on the list. Under known conditions.
And yes...it is the fastest the car on the list for having 650 HP. But my car with only 25 HP more sure walloped it.
The cars that
Just to clarify.
Adam, Erik,
I have a way we can settle this pretty quickly. Use a AX-22 or Driftbox and get some 96.5 kph to 209.2 kph (60-130 mph) runs in a RT-12. We have a decent number of cars in our list with officially verified times that we can use to directly compare your times to (with many more times/cars to come, including mine).
Jean can verify AX-22 runs, and KPG can verify Driftbox runs. Traction will be completely removed from the equation since the cars will be moving from a roll.
This should be fun.
60 -130 mph (96.5-209.2 kph):
5.9x - VRAlexander / Protomotive 1,000+ HP TT (AWD @ 1.3 BAR) / AX-22
6.15 - DMK / EVOMS 800+ HP TT (RWD) / Driftbox
6.6x - Marski / Protomotive 1,000 HP TT (RWD @ .86 BAR) / Driftbox
6.6x - Jean / Protomotive 3.8L 993 TT (RWD) / AX-22
7.93 - KPG / Ultimate MotorWerks 640 HP TT (AWD) / Driftbox
8.10 - 9Eleven / Orton 530 HP GT2 / Driftbox
8.76 - Scotty slc / Techart 510 + EVO V-Flow (AWD) / Driftbox
9.10 - Bill S / 993 Ruf R Turbo 490 HP / AX-22
9.56 - Topgun / X50 TT with Revo software (AWD) / Driftbox
10.96 - Woodster / Orton ECU & exhaust TT (AWD) / AX-22
This should be fun.
It's winter here and the car isn't moving for a while.
RUF Sweden will be happy to add a car to the list. Hopefully a 996TT with RUF 650 hp kit. But it will take until the summer I'm afraid.
It's winter here and the car isn't moving for a while. http://www.rs6.com/smilies/snow.gif
Originally Posted by Restek
Results:
km/h........RT12
0-100....... 3.4
0-200....... 9.8
0-250....... 15.4
0-300....... 24.8 !!!!
km/h........RT12
0-100....... 3.4
0-200....... 9.8
0-250....... 15.4
You can tell from the 0-100 km/h time that it didn't get nearly as good of a launch as the RT-12 did, but once it got rolling...it was MUCH faster.
km/h........Gemballa GT750R
0-100....... 4.1
0-200....... 9.4
0-300....... 21.7
Adam, Erik,
This should be fun.
This should be fun.
I won't be able to do this for at least another month or so though.
also, I suggest Leon get some runs in. the fuel we have here in my country is little better than mule ****. its LISTED on the pump as 95 octane, but a good friend of mine is in the business, and said that when compared to fuel in Europe or the states, our gas would probably struggle to get rated 91 octane, IIRC.
a lot of guys will regularly fill up with aviation fuel when going to the track, to get the most out of their motors. of course, that f*cks up the cats over time...
Originally Posted by hesperus
as soon as I have our car, i'll be happy to test it. I have a VBox Mini, and can send the data files over to KPG or whomever wants to see them.
Anyway, it's all in good fun.
