Upsolute Dyno Graph
No Way 12%
Originally posted by All Boost
I highly doubt the driveline loss of a 996TT with the front driveshaft disconnected is 15-17%. MAYBE if it were automatic, I'd believe it. But most modern RWD stickshift cars lose only ~12%. Therefore, it's about 508-509 flywheel horsepower. Still not too shabby. :-)
Porsche Exchange dynos more than just Turbos... they will rent to anyone... Evo, Sti, Eclipse, etc. Unlike our Turbos, some cars don't required mechanically linked drums to yield accurate readings without buring up clutch/dif packs.
The front drums didn't yield readings because the front shaft was disconnected, so the readings would be the same as RWD Dynojet.
Believe it or not, Porsche Exchange actually sat there and argued with me that it was OK to awd-dyno a Turbo, so long as you don't do too many pulls, because it'd burns up the dif... I was thinking to myself, "Are you hearing what you are saying?!?!" Of course you shouldn't do it... shouldn't be doing it in the first place. The drums are different sizes on the Dynojet, and they are obviously not mechanically linked. If the center dif were to seize, you could potentially see the car jump right off of the dyno and into the brick wall.
Stephen
'01 Turbo Ti Upsolute
1stephen1.com
Stephen
1stephen1.com
Drivetrain loss figures being tossed around are only guestimates anyways. As long as we use the same... say 15% w/o driveshaft, and 18% with, then all else will be the same for relative analysis. If you really want to figure out the drivetrain loss, then do a coast-down on a dyno to figure out parasitic loss of the drivetrain... kind of a reverse dyno.
Also, to calculate for the correction factor, you are suppose to divide your measured power by (1.0 - correction factor). So, in my case, using a correction factor of 15%, you get:
454.9 RWHP = (454.9 / .85) crank hp = 535 Crank HP
504.8 RWtq = (504..8 / .85) crank hp = 594 Crank Tq
For you proof geeks, the correction ratio is multiplied by the crank hp to get resultant whp, therefor, to derive the crank from the whp, one must divide the whp by the correction factor to get crank. QED.
Stephen
1stephen1.com
Stephen
1stephen1.com
I thought that Evo's Dynojet was RWD while the one at the Porsche Exchange was AWD? That right there could skew numbers since they're not the same dyno.
Seems kind of pointless that a Porsche shop would spend the extra money for an AWD dyno when most of the AWD cars that they service wind up disconnecting the front driveshafts anyway because the AWD Dynojet is not the type of AWD dyno that Porsches should be used to dyno on. I've heard of Porsches blowing center differentials when dynoed in "AWD mode" on AWD Dynojets. So why would the Porsche Exchange go and purchase an AWD Dynojet? Seems like a waste of money...they should have went with the AWD Mustang dyno that GIAC and AWE use!
Lou
In terms of 1/4-time and trap speed, how do you think your car would compare to some of the cars in the shootout? From the article, 3 of the 9 cars scored less peak HP than your car, granted the 'shootout' used a different dyno to get the numbers.
Originally posted by oruehr
Can we talk about the A/F ratios.
The Upsolute has been dynoed before and we have all seen the chart from AWE in December.
The NEW information here is A/F ratio. I'd like to know how they compare the GIAC, any ideas?
Going off my memory here, but iirc, the GIAC Stage II chip shoots for 12.0 at the lower RPM range at WOT (not sure if it's closed or open loop at that point), and at the upper range, settles to around 11.5.
Stephen
Josh/AWE
04-02-2020 06:38 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 12:48 PM
