centerlock hubs for 996 turbo
Originally Posted by scottporsche
I am building a race car so I want center lock hubs NOT dummies!
i have centerlocks. parts are available from porsche racing. i am using fikse wheels both for the street and for the track. i don't believe that you can use wheels that are already drilled on centerlocks as there is no thrust washer. also you will need a separate 32mm socket and a torqe multiplier to use with a torque wrench.
carlos
carlos
I have spoken to Porsche racing in Australia and they say no one has put centerlocks on a 996 turbo which is rubbish. They also say that GT3 cup car hubs will not fit. This is why I need some help.
Originally Posted by Zippy
With the BBS racing wheels, the primary use is for center locks. You can see these wheels on race cars on TV. Getting the holes drilled for your bolt pattern is an option. Unfortunately, if going with the bolt pattern, BBS do not offer a BBS center cap option. The FVD dumby center locks are the only option to fill the hole. At least this is how I understand it to be.
regards
Suman
Originally Posted by Highhats
Actually I got mine from BBS USA cause they were in stock and FVD had to ordr them. So BBS does have them bro! I think they were about a littl under a hundred a piece.
regards
Suman
regards
Suman
Yeah call Zack at BBS, he definetly has them.
-Suman
-Suman
THAT'S BIZZARRE! I e-mailed BBS head office last fall and they said there was no (BBS) center cap option??
