UMW Stage 3A Zero Clearance Breaks New Ground: Dyno Sheet
Old 01-20-2007, 10:34 PM
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Originally Posted by iLLM3
Does a brick wall come with the kit too???
Tom we'll see about getting left behind, DRIVE MY DAMN CAR, you will be overly impressed i guarentee it, its FAST man, BELIEVE ME!
Just joking, Cant wait for a ride!
  #197
Old 01-20-2007, 10:39 PM
iLLM3's Avatar
I know i know, listen i have plenty of time, i want a ride in your car before anything
  #198
Old 01-21-2007, 12:21 AM
tradin1's Avatar
tradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to behold
Originally Posted by KPG
Tom and I are using an upgraded version of this kit to handle the extra TQ..and no, there wont be any pictures of it
me too...
  #199
Old 01-21-2007, 12:23 AM
tradin1's Avatar
Just some tweaking of the pressure plate...
...nevermind, that is top secret....
  #200
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Hmmm...I was wondering when the founding member of the stg3B club would make an appearance.... Kevin
  #201
Old 01-21-2007, 12:27 AM
tradin1's Avatar
been lurking per UMW request, until the car is on the road that is.
  #202
Old 01-21-2007, 12:38 AM
tradin1's Avatar
Originally Posted by jags911tt
Tom,
Im not concerned about what others are running with stock motors. The 3a kit is being advertised as a setup that does not need a motor build, nevertheless with 800hp a motor build should be required. Kevin from UMW himself is saying that 650 crank hp is in the red zone and 700hp is pushing it.
Basically this dyno sheet is not representative of what a 3a kit will be producing.
Jag
Jag
this is a sign of what will be comming in a 3b kit with a motor build. no one with 3a will have the tunning to run this kind of power, not from UWM that is.
these numbers were hit in a 3a kit that was thought to have had a motor build by RUF; as it turned out the car had stock internals, so the tuning was dialed back and the 3a was born.
people like KPG and myself that are doing the full motor/heads/trany build will get the 3b tunning that will be at least this power level, if not higher...time will tell.
  #203
Old 01-21-2007, 12:41 AM
KPG's Avatar
KPG
KPG is offline
Did you say higher.... Kevin
  #204
Old 01-21-2007, 12:46 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Dude you just cleared up all the confusion in two posts. Wow - you explained better than the master himself.
  #205
Old 01-21-2007, 12:54 AM
iLLM3's Avatar
BTW Jags, a little birdy told me .. ......
  #206
Old 01-21-2007, 12:57 AM
tradin1's Avatar
Ben has a 3b correct, built engine.
no, stock motor.
  #207
Old 01-21-2007, 01:05 AM
KPG's Avatar
KPG
KPG is offline
Originally Posted by cjv
Sounds familar. Are you reading my thread?
By the way, 9000 rpm's ........... better use the three indes pump instead of the two index (GT3 pump) as you alluded in later posts.
I havent...but maybe Kevin has. I dont think the engine will be running that high, but I guess the crank is capable of those rpms... I am looking for a very safe margin on this motor, nothing more.kevin
  #208
Old 01-21-2007, 01:20 AM
jags911tt's Avatar
Whats that then - pm me Ill
Jag
  #209
Old 01-21-2007, 01:26 AM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
[QUOTE=cjv]Sounds familar. Are you reading my thread?
By the way, 9000 rpm's ........... better use the three index pump (965/GT1) instead of the two index (GT3 pump) as you alluded in later posts. "
More like this thread of UMW Link
  #210
Old 01-21-2007, 08:11 AM
KPG's Avatar
KPG
KPG is offline
This is what a three index pump looks like
The cost of a two index pump ........... about $800.00 and a little machine work. The cost of a three index pump ............ about $10,000.00 and alot of case/pump machining.
The 3index pump is only 10K? Phew, for a minute there I thought it might be expensive ...Kevin
Quick Reply: UMW Stage 3A Zero Clearance Breaks New Ground: Dyno Sheet
