UMW Stage 3A Zero Clearance Breaks New Ground: Dyno Sheet
#361
Here are some pics from the UMW head project. The finished port is on the exhaust side. The unfinished is from the intake and is used to show just how rough the casting is in stock form. There will not be any pics posted of the intake side, but the exhaust side shows the work required to get 300+ cfm flow. The head ports are all port matched to the gaskets as well so there is no excess gasket material that will impede airflow. We are very close. Kevin
#363
Originally Posted by cpu77
That porting is beautiful!
#365
Originally Posted by KPG
There has been a lot of talk lately about alternatives in the 700+ HP category, and I think these new turbos will become the benchmark. These are the stage 3A turbos running on race gas at <1.3 bar. The 1.3 TB shutdown has not been removed and will protect against any overboost situation. These turbos have no compromise, huge TQ down low and incredible HP up high. This dyno sheet was run on Kevin's DynaPac dyno that he uses. To those who may question this type of dyno, keep in mind this is the exact unit Todd Knighton at Protomotive just purchased for his shop. For those who are wondering what STG3B will accomplish...Imagine this power with rods and high flowing heads and a 7500 Rpm redline...For 28K....Enjoy
Rpms...Wheel Tq...FWtq........WheelHP...FWHP
2000...328...........400..........125..........152
2500...365...........445..........175..........213
3000...470...........573..........262..........319
3500...550...........670..........375..........457
4000...580...........707..........450..........548
4500...590...........719..........500..........610
5000...580...........707..........550..........670
5500...520...........634..........540..........658
6000...500...........607..........575..........701
6500...495...........603..........620..........758
7000...480...........585..........640..........780
This setup produces 400FWTQ at only 2000 rpm but also makes 780HP up high. All conversion figures are with an 18% loss since this is AWHP and TQ.Looks like you can have your cake and eat it too ....makes me want my 3B that much more...Kevin
Ryan
#369
Originally Posted by cjv
I am surprised to see a "port match to the gaskets" on the exhaust ports? A slight upper lip (shelf) has proven to eliminate harmonic valve distortion, which does lead to some loss in power.
#370
Chad, just curious....are we doing anything correct? I have yet to see anything posted from you that is positive ....rods are too heavy, harmonic valve distortion, liner issues..etc... Please brighten my day and tell me what looks good Kevin
I'm use to seeing lighter material rods for 8000+ motors. The liners in themslves are not an issue. Short rods have a sharper angle which in turn puts more pressure on the side walls. By lengthening the rods you decrease the angle and in turn apply less pressure on the liners. You can also strengthen the liners. Porsche in the different GT3 motors chose to lengthen the rods. Harmonic distortion as caused by matching exhaust gaskets is not new technology.
Just like stock rods became to be an issue above 700 hp, other items will become known issues above 800 hp and 8000 rpm's. We have made so many mistakes and redone things some many times I shutter to think about it. My opinion is worth exactly what it costs. My comments were made to help not hurt. I won't comment anymore. Please accept my apologies.
#371
Kevin, you are just dancing to a beat of a different drum. Heck, maybe I'm all wrong. My comments are not made to be critical.
#372
Whatever it will Im sure it will kick some ***...
markski
markski
2001 996TT 3.6L and stock ECU
#375
Sure does.... Tom and I just decided to go a step further with the GT3 crank and substantial case machine work and mods...With these mods we can put on a much larger turbo than the 3B kit and run it much higher... 3B will just have rods and heads but no upgraded crank or casework and will have a restricted redline of about 7500 I would guess. Kevin G
