HELP - Stock Bose Radio wont play sound
check the blue fuse in the foot panel all the way to the right I believe 4 rows down and the second one over. I beleive thats the one. I posted before about this beofre check my past posts. good luck. I had the same issue. Its a blue one for sure on the right side.
-Suman
-Suman
My stereo did the SAME THING a few months ago too. I took it to the dealer and it was the CD Changer that was broke. The dealer told me that on the 03+ models the new fiber optics system shuts everything down if something goes wrong within the loop. They installed a new CD Changer under warranty and it works perfect.
I hope this helps....
ROB
ROB
my last 3 porsches have done this (986, 996 series). the amp does need to be replaced but you can usually just turn the car off, lock the doors and then unlock and then restart the car. 9 out of 10 times this will work. however, it happened again in my turbo last week and it took a few series of this routine to get it to work again.
good luck - if your car is out of warranty, i wouldn't buy a new amp. i'm sure it's some coin
Thanks for the suggestions... I probable need to step up and drop some coin and get an aftermarket sysem to do it right...
im having almost same issue with one i just bought today, 02 996tt 6400 miles on odo. ne ways he said since he changed battery it did it. No power at all to head unit, no nothing. will not turn on. checked fuses, there was 1 bad one, fixed it but that did not solve issue...
