What are KKK K64 turbos
Old 01-24-2007 | 02:55 PM
sand bandit's Avatar
sand bandit is infamous around these parts
I'm new to the forum and have a newbie question for you. I was reading the Porsche brochure about the 996 TT -S and it says
" Holstered in parallel on either side of the engine, the KKK K64 turbos each serve a separate cylinder bank with up to 12.3 psi of intercoooled boost that is virtually linear in progression".
I've read about the X50 having K24 instead of the K18 turbos. Does the S have something different or is this a K24 just worded different. I was also wondering why the X50 claims 450 HP and the S claims 444 HP? Are these the same turbos?
Old 01-24-2007 | 03:13 PM
ZLP's Avatar
ZLP
ZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud of
Typo, there are no such things as K64's. K36's are as big as they ever came in the Porsche factory race cars.
Old 01-24-2007 | 05:21 PM
WOODTSTER's Avatar
K27's and K29's are popular for the single turbo aircooled Porsche crowd.
stock 996TT (and 993TT) are K16's (not interchangable)
X-50, Turbo S, and GT2 all came with the K-24's.
Most of the high performance tuners base their High performance
turbos on a K24 and then use a larger turbine or just go to a
larger Garrett ball bearing turbos.
K16 == bad, K24 == ok, K24/K26 == better,
GT35R's == efffing Kick-***...
MK
Old 01-24-2007 | 07:50 PM
bluetosman's Avatar
bluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to behold
Gt35r
what about lag
Old 01-24-2007 | 08:26 PM
WOODTSTER's Avatar
See Markski's video....Power from 3500 to 8200.
Power band wide enough for ya ?? LOL!
MK
Old 01-24-2007 | 09:06 PM
Would a GIAC ECU flash void a warranty?
Old 01-25-2007 | 01:02 AM
crazy1323's Avatar
crazy1323 is infamous around these parts
Luckily i found a picture of the K64 turbo, what ever you do, dont tell Alex. Also, you need a car that revs to about 20,000 to get it to spool
Old 01-25-2007 | 12:36 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Does a GT35R mount up like a K24 or is a different manifold required? I have used dual ball bearing turbos on all of my cars thus far and the performance additive is astounding compared to a traditional turbo. I'd like to do the same for the TT when i finally pull the trigger on one.
04-28-2022 01:38 AM
COBB Tuning
01-29-2022 10:42 AM
Christian
08-24-2015 01:56 PM
johnny.dangerous
08-21-2015 11:48 AM
PelicanParts.com
08-20-2015 03:57 PM
Quick Reply: What are KKK K64 turbos
