Weight Savings
#76
Originally Posted by heavychevy
So is it or is it not the same piece that CJV mentioned that saved almost 50 lbs? Also how did you get 7lbs from the Wiper delete when most people get 3lbs?
Did anyone call him?
#77
heres the one for straight pipes:
996 Twin Turbo Sports Imported Racing Catalytic Converters with
Muffler Bypass Pipes $1,995/set click to enlargeDescription:
- All 996TT/X50/GT2 Products
- Imported sports racing catalytic converters with straight pipes that eliminate the bulky heavy stock 997TT factory exhaust system. Essentially your 996 Twin Turbo you will have sports race catalytic converters connected to straight pipes to your tips on both sides. Very aggressive sports car exotic sports car sound like a 935 and 962. Street and 50 state emissions legal and complies with factory Porsche warranty. Very cool and very aggressive sound.
- Saves 50lbs versus stock 996TT exhaust system.
#79
Originally Posted by Divexxtreme
You guys come up with an accurate, comprehensive weight savings list and I'll make it a sticky.
FYI...my RWD conversion saved me 120 lbs. That's front axles, driveshaft and diff guts.
I took 4 parts,
1. the heavy cast differential,
2. the light drive shaft,
3. R front axle
4. L front axle.
I weighed myself on a very accurate scale then held each individual piece and weighed mysel again and subtracted the difference. The total was about 68 lbs. Am I missing some parts that you weighed and I didnt?
Tom, I did the same with the rear wiper assembly and got 3.2 lbs.
#80
here is some interesting reading on weight loss nuts from "another" forum
http://forums.rennlist.com/rennforu...ad.php?t=122709
http://forums.rennlist.com/rennforu...ad.php?t=186640
also remember a gallon of gas weighs 6.25 pounds so 8 gallons or half a tank is another 50 pounds and a full tank during a race is an extra 100 pounds!!
figure each decrease in 10 pounds is about an additional hp!
Remember YOUR results may vary!
#81
I just removed the spare tire and other associated components, as well as the rear wiper and associated parts.
Weights on my scales (3 different sets) were as follows:
Spare tire and wheel was 28 lb 8 oz. Jack assy., tool pouch, inflation pump, wheel well cover and
wing bolt with washer was 10 lb 10 oz.
TOTAL for wheel well contents was 39 pounds 2 ounces.
TOTAL for wiper assembly and all related components was 3 pounds 13.5 ounces.
#82
#83
Originally Posted by rwm514
Thx. So are you going to be going without your spare now? Ive thought about doing so as well but what about getting a flat?
#85
#87
Originally Posted by F**K
Wow, this is exactly what I've been wanting to do. My sunroof does nothing but rattle, steal headroom, and **** me off!
How'd it work out, any fitment or other installation issues? Is a carbon roof safe for street use? Would it break up in a rollover?
#89
Originally Posted by wirx
but how heavy are speakers and door paddings?
#90
For What it's Worth I remove a couple of items and weighed them last weekend: Figures from my C2 - Space saver spare, w/ toolkit an jack was 34.5 lbs
My rear seats and associated hardware were just about 22 lbs on the nose.
I have yet to remove the rear belts and buckles but when it warms up again I'll post exact weights for them.
C2 may be a bit different from turbo...but it seems like the accurate weight for the spare and tools should be 34-38 lbs
Accurate weight for seats 21-25 lbs.
***Also for those of you that head to the track...a full windsheild washer resivoir will weight a pretty penny. Making sure it's empty will save you 10 lbs or so***
-Andy
-Andy
