Rattle from rear passenger side ?
I've had this rattle which is progressively getting worse - sounds like a cable or something tapping against metal,
Used to only happen under hard acceleration at a certain speed / revs, sort of like a resonance rattle - now it's there when going over un-even pavement.
Before I tear into the interior rear quarter panel - I was wondering if anyone had any ideas / suggestions as to what to look for ?
Thanks Tim
Thanks Tim
How do I check the rear passenger window ?
Sorry to a sound a little dumb - but how do I check it ? It doesn't appear to be loose and as far as I can see there's no loose trim around it.
Is there something specific I should look for ?
Thanks again, Tim
Thanks again, Tim
I have this same problem, I'm probably going to take off my front and rear passenger side door panels. It sounds like something tapping against metal or maybe a speaker that is loose. I had a rattle coming from my e-brake so I took off my rear center console and found out that when the ebrake wasnt being used the steel cables and holder would bang against the metal. I just wrapped it in felt and now its gone!! lol If I solve this second rattle I'll let you know how I did it.
pwdrhound
08-23-2015 07:36 PM
