How to remove the driver side air vents?
Try to replace with CF air vents but can't remove the factory vents cuz the light switch.
Passenger side is easy, but can't figured out on driver side.
Thank you!
Thank you!
Ah, this is a good question. In order to get the light switch **** off, you need a small straight pick. Pull the switch out towards you and you will see on the bottom of the **** there is a cutout, insert the pick in the cutout and the **** will come off, exposing the all familiar torx screw. Also, make sure when you pull out and install the new vent not to break the vent linkage on the side of the assembly.
Good Luck!
Kevin H.
Good Luck!
Kevin H.
Good Luck!
Kevin H.
Good Luck!
Kevin H.
04-28-2022 12:38 AM
pwdrhound
08-23-2015 07:36 PM
