SF Bay: where can I weigh my car ?
Is there a trick to get a car's weight measured in the SF Bay Area ?
I assume that the CHP truck scales on highways are not a good idea, so what are the alternatives ?
A grain elevator, truck weigh station, junk yard, but these scales have 1-200# variation built in, so a little inaccurate.
Most drag strips will have very accurate scales, but you are better off getting an estimated weight when corner balancing as willis mentioned.
hey bro!
I'm located in Morgan Hill... i think my neighbor whos my friend has one... he asked me if i wanted to corner balance my car... i said sure but i was in hurry that day....ill ask him how accurate it is...and if he still has it....i'll shot you a PM when i find out cool?
Enrique
Enrique
I think if you do a search, you'll find many discussions in the past about the benefit (or lack thereof) of corner balancing. Basically, it's a way of further fine-tuning your suspension set-up. Along the way, you find how the weight of the car.
http://www.customalignment.com/
Originally Posted by CLS
I have a suggestion why not get your car corner balance and weight done all at the same time at Custom Alignments in Mountain View. This is a top notch business I highly recommend, ask for Joe.
i took my supra in 1.5 years ago to get coilovers put on. afterwards, thee tires kept hitting the inner fender and CA refused to see the car for "3 weeks" - they're back wait. (never mind, they had just worked on the car 2 days prior and should have seen it just to fix it.)
fine, i'll look into it myself. what i found when i took off the wheel HORRIFIED me! the main bolt for the front A-Arm was just DANGLING! it was beyond loose.
never ever again.
- chuck
Originally Posted by BLTZKRG
I have a set of digital corner weight scales if anyone would like to use them.
Drop me a pm, I'm in the Bay Area
If any of you guys locally in SF Bay area want to measure your corner weights I have a storage space in Pleasanton, you can all come around and mess around with the scales one Saturday Morning
I also have the Camber measuring tool
