Modded Turbo, What Will I Run
Old 02-01-2007 | 10:46 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
well, you said you weren't going to be launching hard right? Not sure if you've taken the TT to the drag strip before, but it's not an easy car to get off the line. Not saying your car can't run faster than that, just saying these are not easy cars to run in the 1/4.
Originally Posted by heavychevy
BOOOOOOOO!!!!!!
I would have to really suck at launching to run a 12.1 @ 123 that would be a 2.1 2.2 60'
I wonder how much this wing will hurt me, any way to keep it down for the run?
Old 02-01-2007 | 10:49 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
LOL the drag strip you live by is not going to be open until March. We have to drive all the way (about 2.5 hrs) south to the Macon area. I cant wait to see you at the strip with Al's (ahem I meant the 750hp) Porsche. Or would that be Paul's you are reffering too. You must really know how to take my money, because my ego wont let me have two turbos in the same area faster than mine.
The 750 is a 997tt not a 996tt.
Old 02-01-2007 | 11:00 PM
heavychevy's Avatar
Yeah you're right, but if I run a 12.1 all the soft launch goes out the window. Yeah I am starting to learn that it's not so easy to take off in the TT but I can get regular 2.0's in a 3900 lb rwd E39 M5 then I can get less in the turbo for sure. I expect 1.9's with a maybe a couple 1.8's. and besides I got Neil lining up a New Clutch and LWFW for me anyways so the stock one is expendable.
Old 02-01-2007 | 11:10 PM
maxwell's Avatar
I have no idea what you'll put down. But I know what happened the first time I took the TT to the track, after having owned it for 5 years. It was much less than I expected.
Launching a rear wheel drive m5 is a whole different story than launching an awd turbo porsche. Just make sure you keep your time sheets!
Old 02-01-2007 | 11:21 PM
heavychevy's Avatar
I'm not a drag strip rookie, I probably had 100 passes in my M5
I am basing the speed of this car on how much faster it is than my M5 and how much slower it is than my Corvette. My Vette trapped 131 with 680 rwhp and awefully bad 60's foots I figure I can get out of the whole a lot better in the TT and I honestly think it will trap 123-125 like markski said.
Neil@Orton's Avatar
Dez drop by the workshop and go 2WD for the strip.
Neil
Old 02-01-2007 | 11:25 PM
heavychevy's Avatar
Neil
Hmmmmmm. Taking that into consideration.
On a side note, how much weight do you think you can get off the car with the full RWD conversion, not that I want it just yet, but just to know.
Old 02-01-2007 | 11:29 PM
iLLM3's Avatar
Dez goodluck buddy, dont get all hung up on numbers, it isnt exactly setup for drag racing as you know, should pull a decent number if you get off the line well
BTW Scott weighed his drivetrain components in at 120lbs for the RWD conversion!
Old 02-01-2007 | 11:30 PM
Neil@Orton's Avatar
I think it's about 50-60 lbs.Is Jenko taking the GT3 to the strip.
Neil
Old 02-01-2007 | 11:38 PM
JWC's Avatar
JWC
JWC is infamous around these parts
I will guess 11.825. I hope I am correct or at least the closest I need my 1 rep. point back somebody (no name) took from me. Good luck.
Old 02-01-2007 | 11:42 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
For reference...I got a 1.77 - 60' time on stock size, street tires.
Old 02-01-2007 | 11:52 PM
Divexxtreme's Avatar
Yep. My stuff weighs 120 lbs on a calibrated scale. It all depends how much you remove when you do the conversion.
11.8x @ 124.x .
Old 02-02-2007 | 12:57 AM
Turbo Fanatic's Avatar
These cars are hard to launch. Hard to believe motor trend pulled an 11.86 in a stock X50.
http://www.motortrend.com/roadtests/...50/index1.html
Old 02-02-2007 | 01:03 AM
LUISGT3's Avatar
They must have had a great driver that knows Porsches and told him to beat the **** out of it.
Old 02-02-2007 | 01:04 AM
jenk12m's Avatar
jenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant future
neil, sadly i wont be at the track with dez and the guys. however i will be in the bahamas . keep some slots open for me to bring the gt3 in
Quick Reply: Modded Turbo, What Will I Run
