I blew my MAF
Old 02-04-2007, 11:10 PM
Zippy's Avatar
Originally Posted by KPG
Here you go...
Sweet Box!
  #32
Old 02-04-2007, 11:12 PM
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by Zippy
Sweet Box!
I'll send you the pics of MY box soon...Kevin
  #33
Old 02-04-2007, 11:15 PM
Zippy's Avatar
Thanks! Perhaps you can send a few of the build also. That would be good.
  #34
Old 02-04-2007, 11:19 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
Has anyone with the V-Flow ever data loged to see what the max MAF voltage is un WOT?
Neil
  #35
Old 02-04-2007, 11:30 PM
KPG's Avatar
KPG
KPG is offline
I'll do that...they will be encrypted and self destruct 30 secs after you look at them though....just kidding, they wont be encrypted. Kevin
  #36
Old 02-04-2007, 11:32 PM
KPG's Avatar
KPG
KPG is offline
Neil
Neil...sort of out of my league but wouldnt it have to be clamped at the Max 5 volts since these motors are going way over the designed flow. kevin
  #37
Old 02-04-2007, 11:37 PM
Neil@Orton's Avatar
Kevin,On the car I did i Korea with big turbo's etc the stock MAF was maxing out at 5 volts @ 4000RPM so we had to go to a larger MAF housing to slow the air down.
Neil
  #38
Old 02-04-2007, 11:42 PM
KPG's Avatar
KPG
KPG is offline
Neil
Kevin did the same for his 3A and 3B , but isnt the GT700's using the stock MAF housing? If it is then the voltage would Max long before the car reached redline...so it would have to be clamped at 5 volts...i think
  #39
Old 02-05-2007, 12:06 AM
Neil@Orton's Avatar
Thats correct.I think what is happening on the bigger kits is that the MAF is being pegged long before Red line with the stock MAF housing.When I used the bigger ball bearing turbo's and intake tubes the injectors and MAF were both maxed at 4k.
Neil
  #40
Old 02-05-2007, 01:27 AM
Turbo Fanatic's Avatar
Given the fact that the V-flow MAF fix is basically re-installing the factory waffle inside the airfloe of the V-flow, I think that the voltage pops the MAF theory is out the window. After all RUF and other cars run up to 590 HP with the stock MAF...
  #41
Old 02-05-2007, 03:20 AM
Zippy's Avatar
Perhaps the waffle makes the air flow more uniform, preventing turbulence, resulting in a more stable voltage in the MAF?
  #42
Old 02-05-2007, 12:04 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Neil
This is why I believe that when you look at the evo dyno graphs you see the hp stop climbing at some point and drop.
BLKMGK
05-31-2016 04:32 AM
WheelsupZR1
10-20-2015 08:36 PM
panas001
09-27-2015 02:51 PM
pumalex
09-27-2015 08:58 AM
RyanZS
09-15-2015 12:27 PM
Quick Reply: I blew my MAF
