Who's Running 335 rear tires?
Originally Posted by oak
tom, I have a question about your clearence issue, did you have to clearence the metal "tang" that over hangs at the rear where the rear quater panel body flange meets with the rear body flange there is a metal over hang if you run your fingers over back by where the bumper mount to the body you will feel it there is actually a cut-out in the fender liner for it. funny my clearence issue is with the right side, my left side was fine but I mirrored both sides.
tom, I just tried to dry fit my left side, installed my new evo hoses and the new gt2 rear bracket and new rear liner. it has slightly more clearence. the difference between the GT2 liner and turbo is only a small mounting hole where the shorter rear bracket goes. you could basically just shorten the bracket and relocate and pop a new hole in the liner.
oufan2929
11-08-2015 08:26 PM
L.A.P.
10-19-2015 10:01 PM
L.A.P.
08-23-2015 11:48 PM
Sterlingc1975
08-22-2015 02:30 PM
