996 TT Window Question
Is there an adjustment on the driver's window that goes down automatically the 1/8th inch when you pull the door handle? Mine only goes down 1/32nd inch and sometimes binds.
There are some inverted torx nuts on the bottom of the window carriers. You can access them by putting the window all of the way down and then if you look on the bottom of the door, there are 4 rubber inserts that can be removed, two of which will be covering the adjustments for window pane height, the other two are 10mm bolts that hold the bottom of the regulator.
Kevin
Kevin
04-28-2022 12:38 AM
