What tires to get?
PS2
http://www.tirerack.com/tires/BigPic...wall=Blackwall
There. Now there's nothing to think about.
Ciao
Ciao
Originally posted by MKW
For some reason, Pirelli has not produced a Rosso in the OEM 18" Turbo size for the rear. Can anyone explain why in 2004 , Porsche insists on the original 1987 PZero " slip and slide" tread pattern for their Pirelli OEM Turbo spec tire , and not the Rosso which has been out for years and is used on the reg 996 and GT2 as OEM ?
Originally posted by JASCLASS
The GT2 OEM tires are Michelin Pilot Sports.
The GT2 I saw at the dealer last week had Rossos. It had the new factory GT3 style wheels so it should be a 2004. The Rossos have rayon sidewalls so they should be relatively smooth and quiet. I think the 315/30 will fit the stock wheel.
Originally posted by john stephanus
Has anyone compared this new Pilot Sport 2 to the Sport Cup? I have the older Pilot Sports and the Sport Cups.
Re: PS2
Originally posted by carbonissimo
estimated availability is 3/08/04 at Tire Rack for
PS2 295/30-18
Ciao
PS2 295/30-18
Ciao
They aslo come in at $350 less for a set. This is what I did with my GT3. Even if you got a set of PS2's eventually...What happens when you get a flat. Tires most likely will be on backorder and you will be dead in the water unless you have another set of wheels with rubber or spare tires lying around....Just my 2 cents
