I have an idea and want your opnions! UNICHIP
Originally Posted by KPG
Goerge, are you saying that you recommend / condone running gt35 turbos on stock injectors and fuel system? Kevin
OK,
I would never use a UC...not even for my G35...however, what about a stand alone sustem like The HKS F-Con V-Pro. It is a GOD of tuning in the VQ communnity.
I local builder/tuner here in the Houston area who is very well known in the Supra Community approached me about tuning my GT2 w/ the V-Pro....I called him back...I wanted to have him install some Nitrous on my G35 (which already has the V-Pro) and maybe I would (if I liked his work/service) then be willing to discuss the V-Pro/G35 idea.
He never called me back (something I hate!) so he won't be getting my bussiness, but I am still intrigued w/ the idea of using the V-Pro.
Any opinions?
Any opinions?
Originally Posted by George@Revo
The cars are running stock injectors and an adjustable FPR. .
That is irresponsible to even suggest. A gt35 will move a lot of air. It no longer comes down to boost, it is pure CFM. That turbo is much larger than the K16, K24 and even the GT28.
Originally Posted by Dr_jitsu
OK,
Any opinions?
Any opinions?
When is a system like that make sense…when building a motor of such into an old chassis or race car.
Thanks, Stephen,
I will stay away from the V-Pro for my Porsche (although they have 32x32 resolution for both fuel and timing maps).
By the way, you ALWAYS return phone calls....
I appreciate your advice.
For the super performing 996TT there is only one place to go.
Suman,
You have a very high performance car and are at a crossroads.
The best bet for you is to call Todd @ Protomotive and discuss your needs.
He uses "real" Garrats GT30's, and 35's (ala Markski, VRAlex and several others), thusly to utilize the Garrats as intended you need custom fab on the header side (ala Proto custom fabbed headers), and custom
exhuast (ala Proto custom exhuast), as well as plumb in water cooling (maybe you already have that). And as long as you are at it why not throw some custom ground cams in the mix and really make it interesting. but most importantly, someone who
not only understands how these turbos work but also understands the fueling, air flow, build specs, etc.
and programming and can DO IT inhouse!
Originally Posted by PorschePhd
You CAN not run the GT35s on that car with a 38# injector. Cranked up to 5 bar or not. Period.
Originally Posted by Highhats
I currently dirve a gt700/750 car with Tial turbos on it. I want to put bigger turbos on the car and re tune it with a UNICHIP set up. Does anyone have experiece with this. I crrently put down 680whp with race fuel. Do you think with bigger turbos I can put down the same power on pump and less boost. Will the UNCHIP provide enough tuning capabilities in order to have the car run properly. thanks in advance
PS Im thinking of going with custom gt35/k24 turbos. Man they just sound good!
-Suman
-Suman
Nice to know someone is taking advantage of 680whp and beyond....
-Suman
-Suman
Dont mess with the car.. u will probably sell it casue too many people got there hands in it and probably will F#CK it up....
run a AX 22 or a driftbox.. see what it does.... if its not enough then another 100 HP will not be either...
doing a gt35 type of turbo will require u doing MAF, fuel system, and tuning... and it means custom....
good luck
makski
2001 996TT 3.6L and stock ECU
TIal called me back and they say now that they would need to make a gt32/k24 turbo for my application still a big turbo. Im talking to steve now to see gt800 turbos and ecu to see if it will make what im looking for. thanks guys
-Suman
-Suman
-Suman
-Suman
Put down the crack pipe and walk away! Unichip on this custom of a setup?
-Suman
-Suman
Guys,
I was going to start a new thread with this, but it sounds like it might work in here...
I might be able to get a CPU with X50 mapping put into my Turbo. It's like taking the brain from a 2004 TT X50 and putting it directly into my 2001 TT. The only mods I have are an EP exhaust and EVO diverter valves, so the turbos and intercoolers are stock. I would probably gain 75hp from both the X50 and EP...do you think I would have any problems? Do I need to upgrade the turbos and intercoolers with this X50 programming? Has anyone ever done this before?
