I have an idea and want your opnions! UNICHIP
#31
An X50 is built to run the air volume of K16s, not K24s. So what will happen is less air from the K16s will cause a surge in fuel when they ht boost. Since the CFM is less with a K16 the system wouldn't know know that and assumes that a K24 is in place. It in turn moves more CFM or volume and would require more fuel.
Some gain would naturally happen. Just not what you would expect.
#32
So, would the very least upgrade necessary to take advantage of this X50 mapping is to upgrade to K24 turbos? Would I need to upgrade anything else with that X50 cpu?
#34
I don't really know. I suspect not good on either account.
Yes, K24s and you are set! Exhaust helps as well so consider this as well.
WheelB
07-06-2018 10:16 AM
alpha motoring
10-02-2015 12:04 PM
