Tiptronics shifting problem?
Old 02-19-2007 | 05:35 PM
GL996TT's Avatar
GL996TT is infamous around these parts
Does anyone know why it automatic shifted when RPM hit at 5K before I use sterring wheel shifter? (PSM off, switched to manuel 1st gear, Stage 2).
Friends of mine also had same problem. (same car and same set up)
Thanks for your valuable info!!!
Old 02-19-2007 | 05:54 PM
Ruf 550's Avatar
Ruf 550 is infamous around these parts
If it happend after you tuned the car, check with your tuner that he down loaded the right ECU program for tiptronic.
Good luck
Old 02-19-2007 | 07:02 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
GL996TT -- Mine does the same thing when I'm less than WOT in first gear. I was told that even in "M" mode it will shift for you in first gear, but will hold to redline in gears 2 through 5.
Old 02-19-2007 | 09:31 PM
GL996TT's Avatar
Mine automatic shift when 2nd gear to 3rd at 5k RPM. It does not hold until the redline.
Old 02-19-2007 | 09:48 PM
tom kerr's Avatar
the car learns your driving patterns and responds accordingly. Do several runs with pedal to the metal let the car redline all the way through (as a professional on a closed road of course) Then try it again, it should take you to redline but only with the pedal to the floor otherwise the car short shifts it for you because it doesnt think you are under or want full acceleration.
Old 02-21-2007 | 08:31 PM
YellowTT's Avatar
YellowTT is infamous around these parts
this is exactly what my car does. when i hit 5k rpm at 2nd gear, it automaically shifts to 3rd.
Old 02-22-2007 | 09:52 AM
Alpha's Avatar
Now I am confused. In "manual" mode I am told the transmission should not shift for you by itself in gears 2-5. I have experienced what Tom says about the Tip learning your driving style in "automatic" mode -- after some WOT driving the transmission will downshift much more quickly, and will hold the gear after abrupt "lifting" of the gas pedal -- but I was not aware that there was any "learning" in the "manual" mode.
Maybe I should have gotten the 6-sp manual ... but then there's the 2nd gear pop-out I would be concerned about ...
Old 02-22-2007 | 10:46 AM
JWC's Avatar
JWC
JWC is infamous around these parts
I have the tip (02). Mine will shift if you don't but not at 5K it shifts at redline. But I do run it hard (sometimes) and I have the Protomotive tune. Mabye send Sharky a PM. I have become quite fond of my as some call it "monkeytronic". It's a blast to drive the only down side now is with the increasded power I will be needing new tires!
Old 02-22-2007 | 01:35 PM
ramone's Avatar
ramone is infamous around these parts
I have a tip, it also automatically shifts for me when i'm in tip mode and its really annoying
Mine isn't tuned.
Old 02-22-2007 | 02:57 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Mine isn't tuned.
WTF
Old 02-22-2007 | 04:01 PM
Alpha's Avatar
Just came back from a short drive ...
I just drove around for 10 minutes in "M" mode and here's what I've found for my car ('01 996tt Tip): 1st - it will shift at redline automatically at WOT, will hold up to redline at whatever spped/RPM unless I'm at WOT and lift quickly, then it will upshift to 2nd; 2nd gear -- holds at redline, no automatic shifting at redline even with quick lift; 3rd, 4th, 5th gears hold in the low and mid RPMs.
Old 02-22-2007 | 04:30 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I am not sure what is going on with the above-referenced Tips, but when driving in Manual mode, a Tip is supposed to hold its gear right up until redline, in every gear, then upshift to the next gear if you rev past redline (not before).
BTW, I have a heavily modified Tip tranny (sent to Germany for mods by 9ff, including replacement of every gear, additional, stronger cluthes, etc, at a cost approaching $10k). It works perfectly. I may be selling the tranny in the not to distant future. If anyone is interested in buying the finest Tip available, that can smoothly handle all the power you can throw at it, send me a PM with a reasonable offer.
Regards,
Craig
Old 02-22-2007 | 08:04 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Regards,
Craig
Quick question regarding the tip tranny. Is the x50 and regular different? Im assuming 9ff can also upgrade the reg tip if its different? Is there programs to raise the redline to 8k for tips? Thanks.
Old 02-22-2007 | 08:55 PM
Craig's Avatar
Porsche insists that the x50 Tip is different and stronger (I have an x50 Tip). Yes, 9ff can upgrade an x50, as they did mine. There are not any programms currently available to raise the redline for Porsche Tips, although it probably can be done.
Craig
Old 02-22-2007 | 09:01 PM
geetee's Avatar
Thanks Craig. I was asking about programing because I remember someone(im thinking it was you but i guess not) stating that they finally came up with a solution and was able to raise the redline.
