Running 1.2 Bar On K-16s
Old 02-21-2007 | 05:52 AM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
Originally Posted by Jean
There is no risk to the turbos in principle, the worse that can be happening is to have performance levels drop. Changing the turbos and IC and keeping the same program is nonsense.
You can boost 1.2 Bar without issues on K16s on a 996 engine but I doubt you are gaining any performance beyond 1.1 Bar sustained, in fact it could be the opposite. The maximum you are seeing is 490-500 hp at the flywheel.
Jean i guess you are right about the 490-500 hp figure because someone also told me that my car with the current mods is suppose to be in the range of this figure, if i wanted to see more i guess i'll have to get the bigger turbos and intercoolers, since the moded ECU was actully programed for the 580 hp figure.
Old 02-21-2007 | 06:11 AM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
jalmood,
You will need bigger turbos, either a K24 or some K16/K24 hybrid that many do. You do not need other than a GT2 intercooler for those levels, TT stock ICs might be a bit tight.
True sustained 500HP is plenty!
Old 02-21-2007 | 09:53 AM
jalmood's Avatar
Thanks everyone for your replies.
BlackHorseTurbo
04-20-2016 11:26 PM
orbelo
08-30-2015 01:26 PM
BauerR
08-25-2015 09:58 AM
The Oss
08-24-2015 09:19 PM
markski@markskituning
08-24-2015 11:07 AM
