Running 1.2 Bar On K-16s
Old 02-19-2007 | 06:00 PM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
Hello guys,
i have a 04 996 turbo which i bought slightly used, the previous owner installed Gemballa power kit with a claimed 580 HP, kit includes:
1) Modified ECU
2) K24/K26 Turbos
3) Sport Intercoolers
4) sports clutch/Flywheel
Later on he sold the K24/K26 turbos and Sport intercoolers when someone offered him to buy them when they knew that he was selling the car, so he reinstalled back the Stock turbos (K-16s) and stock intercoolers.
now i allways see 1.2 bar on sixth gear and the car seems to be puling fine and strong, but how safe is it for the stock turbos to be running at this boost level? am i damaging the engine by running this level of boost with the K-16s?
Please advice
Old 02-19-2007 | 06:13 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
is it holding 1.2, or spiking there just for a second, and holding 1.0-1.1?
Old 02-19-2007 | 06:32 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
1.2 is no problem.
Old 02-19-2007 | 06:41 PM
jalmood's Avatar
It's holding 1.2 . i'm talking K-16s here.
Old 02-19-2007 | 08:39 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Stock K16's at 1.2 bar sustained is well out of their efficiency range and close to overspeed. Kevin, Stephen and others have covered this before...Kevin G
Old 02-19-2007 | 10:02 PM
maxwell's Avatar
thats what I was thinking. From what I've read, 1.0 sustained, and 1.1 peak on the 16's is about all they can handle.
Old 02-19-2007 | 10:36 PM
WOODTSTER's Avatar
So does the car have in theory a modified Gemballa ECU and the stock
K-16's (which are boosting quite high)??
Wow!
MK
Old 02-19-2007 | 10:50 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Wouldnt the mapping in the ECU not be correct?
Old 02-20-2007 | 02:58 AM
jalmood's Avatar
Wow!
MK
Yes that's whats happening in my case, is this normal or is it bad for the turbos?
Old 02-20-2007 | 03:00 AM
jalmood's Avatar
thats what i thought, wasn't he suppose to reprogram the ECU since he has swapped from the K24/K26 to K16's?
Old 02-20-2007 | 03:04 AM
jalmood's Avatar
0.9- third gear
1.0- fourth gear
1.1- fifth gear
1.2- sixth gear
Old 02-20-2007 | 01:31 PM
wross996TT's Avatar
Originally Posted by jalmood
0.9- third gear
1.0- fourth gear
1.1- fifth gear
1.2- sixth gear
OK...I'm a little confused here...My boost is not gear specific. I can achieve the same boost in all gears (notthat I would want to). BTW, how fast are you going with 1.2 boost in 6th gear. You are beyond the useable power of a K16.
Old 02-20-2007 | 01:35 PM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
There is no risk to the turbos in principle, the worse that can be happening is to have performance levels drop. Changing the turbos and IC and keeping the same program is nonsense.
You can boost 1.2 Bar without issues on K16s on a 996 engine but I doubt you are gaining any performance beyond 1.1 Bar sustained, in fact it could be the opposite. The maximum you are seeing is 490-500 hp at the flywheel.
Old 02-20-2007 | 05:22 PM
KPG's Avatar
KPG
Hmmm... People who build turbos for a living have said that overspeeding a K16 is a risk....in principle of course, maybe even in reality.Kevin
Old 02-21-2007 | 04:23 AM
Jean's Avatar
Hmm..I am sure people who build turbos for a living know what they are doing most of the times, in principle, and maybe in reality too, but a K16 at 1.2 Bar is not overspeeding badly yet unless something is wrong with something else. Compressor efficiency is dropping at those levels so the turbine works harder but once air intake temps get affected the ECu will pull the timing and back out the pressure through the WGs and reduce the spin RPMs.
But in fact you even said it yourself below, they are close to overspeeding, but not there, so where is the risk on the turbo?
What do you mean by well out their efficiency levels at 1.2 Bar and more importantly how does that address the risk to the turbos question by the original poster?
