Durametric ECU Readings
Old 03-05-2007, 02:11 PM
manalex's Avatar
manalex is infamous around these parts
Just got the Durametric and it appears that there are several parameters being monitored by the ECU, at least as the Durametric software is concerned. The list is rather extensive. I checked with Durametric and they can not provide definitions of what is being measured, they simply report the values. Does anyone know where I can find more information on the various measurements? Some are easy, RPM for example, but what is the difference between RPM and Spec RPM as monitored by the ECU? Just want a reference of some sort. Here's a complete list in case anyone is curious:
RPM
Engine load
Actual engine torque
Ambient pressure
Mass air flow (HFM)
Altitude correction factor
Supply voltage
Intake air temperature
Engine temperature
Engine compartment temperature
Oil temperature
Exhaust temp. after cat. conv.
Ignition angle
Spec. RPM
Loss adaption, idle
Injection time
Camshaft position 1 deviation
Camshaft position 2 deviation
Actual angle for camshaft, bank 1
Actual angle for camshaft, bank 2
Mass air flow
Carbon canister load
Outside temperature
Actual angle for inlet camshaft, bank 1
Actual angle for inlet camshaft, bank 2
Spec. angle for inlet camshaft, bank 1
Spec. angle for inlet camshaft, bank 2
Oxygen sensing, bank 1
Adaption, range 2 (FRA), bank 1
Adaption, range 1 (RKAT), bank 1
Fuel quantity, tank ventilation, bank 1
O2 sensor resistance behind cat. converter, bank 1
O2 sensor voltage behind cat. converter, bank 1
Corrected sens. voltage ahead of cat. converter, bank 1
Oxygen sensing, bank 1 Lambda Value
O2 sensing, bank 1 delay
Lambda setpoint, B1
O2S volt. ahead of cat. converter, B1
Dynamic value of the O2 sensor, bank 1
Number of dynamic measurements LSU, bank 1
O2 sensor voltage ahead of cat. coverter, bank 1
O2 sensor voltage behind cat. coverter, bank 1
Regulator delay behind cat. converter, bank 1
Sensor-signal period ahead of cat. conv, bank 1
O2 sensor resistance ahead of c.c., bank 1
O2 sensor resistance behind c.c., bank 1
Oxygen sensing, mean value, bank 1
Adaption, range 2, lower (FRAU), bank 1
Adaption, range 3, uppper (FRAO), bank 1
Resist. limit, O2S ah. of cat. conv, B1
Resist. limit, O2S behind cat. conv, B2
Heating power, O2S ahead of cat. c, bank 1
Heating power O2S behind cat. c, bank 1
Timer, active diagnosis
Oxygen sensing, bank 2
Adaption, range 2 (FRA), bank 2
Adaption, range 1 (RKAT), bank 2
Fuel quantity, tank ventilation, bank 2
O2 sensor resistance behind cat. converter, bank 2
O2 sensor voltage behind cat. converter, bank 2
Corrected sens. voltage ahead of cat. converter, bank 2
Oxygen sensing, bank 2 Lambda Value
O2 sensing, bank 2 delay
Lambda setpoint, B2
O2S volt. ahead of cat. converter, B2
Dynamic value of the O2 sensor, bank 2
Number of dynamic measurements LSU, bank 2
O2 sensor voltage ahead of cat. c., bank 2
O2 sensor voltage behind cat. c, bank 2
Regulator delay behind cat. c, bank 2
Sensor-signal period ah. of cat, c, bank 2
O2 sensor resistance ahead of cc bank 2
O2 sensor resistance behind cc, bank 2
Oxygen sensing, mean value, bank 2
Adaption, range 2, lower (FRAU), bank 2
Adaption, range 3, upper (FRAO), bank 2
Resist. limit, O2S ahead of cc, B2
Resist. limit, O2S behidn cc, B2
Heating power, O2S ahead of cc, bank 2
Heating power, O2S behind cc, bank 2
Timer, active diagnosis, bank 2
Tank pressure difference
Leakage volumetric flow
Control deviation, tank diagnosis
Mean amplitude behind cc, bank 1
CC monitoring time, bank 1
Mean amplitude behind cc, bank 2
CC monitoring time, bank 2
Period counter, bank 1
Period counter, bank 2
Dist. since powerfail
Distance with check engine on
Fuel level
Actual P/D factor, tank vent
Spec. P/D factor, tank vent
Sensor-signal period ahead of cc, B1 (OBD)
Sensor-signal period ahead of cc, B2 (OBD)
Tank pressure difference, filtered
Relative air mass, secondary air, bank 1
Relative air mass, secondary air, bank 2
Driving cycle counter
Warmup counter
Rough-running reference value
State: adaption 1 (rough running)
State: adaption 2 (rough running)
State: adaption 3 (rough running)
Cylinder 1 misfire counter
Cylinder 6 misfire counter
Cylinder 2 misfire counter
Cylinder 4 misfire counter
Cylinder 3 misfire counter
Cylinder 5 misfire counter
Ignition counter diagnosis
Rough running, cylinder 1
Rough running, cylinder 6
Rough running, cylinder 2
Rough running, cylinder 4
Rough running, cylinder 3
Rough running, cylinder 5
Reset counter: learn. filter overflow
Reset counter: plaus. test FSE
Pedal value
Pedal encoder potentiometer 1
Pedal encoder potentiometer 2
Spec. throttle plate angle
Actual value, throttle
Throttle position sensor 1
Throttle position sensor 2
Target speed, cruise control
Vehicle speed
Throttle plate angle, potentiometer 1
Throttle plate angle, potentiometer 2
Hot film MAF
Power supply
Ambient pressure
Press accelerator full load detection
Press accelerator idle detection
Medium-pressure switch
A/C request
Start enable switch
Disturbance switch
Stop light switch
Stop light switch
Immobilizer
Fuel reserve signal
Cruise control readiness
Clutch switch
Cruise control - store/accelerate
Cruise control - decelerate/resume
Ready status - cat. efficiency
Ready status - tank vent
Ready status - sec. air system
Ready status - O2 sensors
Ready status - O2 sensor heater
Boost pressure of sensor
Spec. air charge
Setpoint boost pressure
Boost pressure control deviation
Boost pressure control P/D factor
Corr. factor for BPC with charge air temp.
Corr. factor for BPC with knock control
Boost pressure limit for coolant failure
Boost pressure limit for extreme exhaust temp.
Thanks in advance,
Alex
Old 03-05-2007, 06:36 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Wow, thanks for all the info!!
Geez i so want to get one !
Hmm can we change certain stuff ?
any examples ?
like make the engine run 10C coolder ? etc ?
Old 03-06-2007, 09:15 AM
manalex's Avatar
f1crazydriver:
Don't think you can change anything. The program, while in data logging mode, simply conveys what the ECU is measuring.
Any one else? Do any of the "boost" measurements toward the bottom of the list have anything to do with Turbo Boost? Is there a reference in a Porsche repair manual that I can look up?
TIA,
Alex
Old 03-06-2007, 11:11 AM
ebaker's Avatar
ebaker is infamous around these parts
Will the Durametric datalog and/or read real time all the listed variables?
Old 03-06-2007, 06:09 PM
manalex's Avatar
It will, but it should not be used as a substitute for a true data logger. Apparently the ECU reduces the sample rate as the RPM increase, particularly on less critical functions.
It's issues such as these that I would like to get more information on as well.
Alex
Old 06-19-2007, 07:12 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Any luck with this Alex? I can't find any info on these parameters either.
Old 06-19-2007, 09:46 PM
manalex's Avatar
Gave up on this. No one seems to know. But let me know if you find something out-I am still interested.
Old 06-20-2007, 01:25 AM
tone01's Avatar
tone01 is infamous around these parts
durametric
what does one of these cost
Old 06-20-2007, 01:26 AM
tone01's Avatar
durametric
oh and where can i get one at
Old 06-20-2007, 03:44 AM
manalex's Avatar
Old 06-20-2007, 06:38 AM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
Alex-
I tune these ecu's for a living...most of the list makes sense to me.
Shoot me a PM with a few that you are particularly interested in and I most likely can help you out.
Old 06-21-2007, 03:28 PM
StealthAuto997's Avatar
StealthAuto997 is infamous around these parts
There are changes to certain parameters that increase power and there are other changes that really don't do much, just look good on paper. Keep in mind most of Porsche's settings are for perfect from the factory, their tuning just needs to be conservative due to emissions. This means by simply tweaking the timing and a/f's power can be made.
I worked for Powerchip for about a year and will be glad to answer any further tuning questions you may have.
-Aaron
BLKMGK
05-31-2016 04:32 AM
BonitaBeast
Cayenne 955/957
11
10-16-2015 06:14 PM
jdbaker
09-19-2015 10:34 AM
Yogi911
09-09-2015 08:20 PM
arhim22
09-07-2015 08:49 PM
Quick Reply: Durametric ECU Readings
