Best air intake for 996TT???
Thank you kaizu for your help.
EVO V-Flow Induction System seems to be very good.
What do you think about 996 TT High Performance Air Intake System with BMC Air Filter from FABSPEED? www.fabspeed.com
What's the best of 2?
Any other 6speeders can help me?
Best regards.
Best regards.
What is MAF??? Sorry I'm from Belgium and I'm a new owner of 996TT.
So, if I understood well I can't put an aftermaket airbox in my 996TT because I'll broke MAF? I just want a racing exhaust, chip and sport intake.
Thank you.
Thank you.
You should be okay with an exhaust, chip and the V-Flow. MAF can go bad on a bone stock car too, but due to more airflow than the stock MAF can handle the risk of blowing it up with a V-Flow increases quite much (but yes, there's a lot of members without problems with the V-Flow)
Hope this helps
Stock airbox with a sport air filter is a cheaper and safer way to go but of course V-Flow gives a bit more power. I would put a BMC or K&N filter only and save money for other mods (suspension and better brake pads!!)
For more power without changing the turbos, I suggest the FVD intake plenum. It seems to be great "bolt on" part but I don't have own experience of it...(the only downside might be the installation, it isn't quick.)
Hope this helps
Originally Posted by Schnitzer
Do you agree all that original airbox with BMC or K&N is the best and safe solution?
I need more feedback guys!!!
Thank you in advance for your help.
Best regards.
Best regards.
