Headers Installation
Hey guys, almost time to take the beast out!.. extremely syked right now!.. I purchased the EVO headers during the winter break and have not installed them yet.. is this an easy install?.. do i need to change the gaskets?.. any information would be greatly appreciated!
ryan
ryan
Just went through this (again) this past weekend. It is VERY easy to swap out the exhaust headers. You will need new gaskets at the cylinder head and the turbo. I would also get 6 new locking nuts (3 per side) for the studs at the turbo's. The headers can be swapped without taking anything else apart. If you haven't used anti-sieze on the threads, you may want to buy new studs (just in case). I use anti-sieze on all the threads. Remember to reduce torque by approx. 20% if using anti-sieze.
If you just swapped out the headers for some cleaned up ones, what would just that alone add in actual crank horse power for a ttX50?
By the way I've seen the acutual factory headers, and great pics posted here. Was appalled by the amount of moulding flash that was left in the airflow path!
I cannot believe that Porsche AG would allow crap like that to leave their factory. Is it because it is within their manufacturing tolerances? Or, as usual, their greed for their profit margin.
Wasn't that kind of flash the very first thing the hotrodders used to clean up over 50 years ago?
Anyway, your info on the incremental benefit this would give us would be appreciated. Thx
torque sequense and specs
Position the nine fastening screws on the cylinder head by hand and tighten in two stages.
First stage to 25 Nm (18 ftlb.).
Second stage to 33 Nm (24 ftlb.).
Tighten in accordance with the sequence shown.
Originally Posted by WOODTSTER
Scott,
You are joking right?? Didnt Todd make you custom headers??
mK
mK
C.
