Weight diet/ horsepower gains.
Old 03-08-2007, 01:09 AM
flatsixnut's Avatar
flatsixnut is infamous around these parts
Figured one of you horsepower junkies in here could answer this question.
What is the weight savings to horsepower gains calculation?
Old 03-08-2007, 01:24 AM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Old 03-08-2007, 11:28 AM
buddyg's Avatar
I believe each 100 lbs in weight reduction is equal to adding 10 hp and can reduce your et's about 1 tenth. Loose 500 lb's and you should be able to drop 1/2 second from your time.
Old 03-08-2007, 11:37 AM
Kevinw23's Avatar
Kevinw23 is a jewel in the roughKevinw23 is a jewel in the roughKevinw23 is a jewel in the roughKevinw23 is a jewel in the rough
What are some of the easy ways to reduce weight to a stock vehicle? Are there any?
Old 03-08-2007, 11:51 AM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
I think replacing the stock seats with GT3's are the easiest way to start...
Old 03-08-2007, 12:52 PM
Joe Weinstein's Avatar
The GT3 seats and light wheels.
Old 03-08-2007, 02:27 PM
Kevinw23's Avatar
Anyone know if my SSR's are lighter than the stock wheels? They came on the car when I bought it so I didn't see any original specs. If it matters they are the 18's.
Old 03-08-2007, 03:22 PM
SallyMobile's Avatar
SallyMobile is a jewel in the roughSallyMobile is a jewel in the roughSallyMobile is a jewel in the rough
It depends on what HP and weight you're running stock.
On a 3000 lb car with 100hp, you're at 30 lbs per hp. That means you need to save 30 lbs to equal 1 hp.
On a 3400 lb car with 415 hp, you're at 8.2 lbs per hp.
Old 03-08-2007, 03:32 PM
And note that the real effects of lightening is more palpable
than a horsepower figure. If you say you have a '415 hp' car,
the fact is that even at the drag strip, your car is developing
415 hp at about half a second of the run at best. 95% of the
time your car is at a different RPM, producing significantly
less power. Your car is, however, the same weight at all times,
so the real effect of weight loss is as if your torque curve was
raised across the board. Weight loss is *better* than a power
adder because power adders can add lag, or lower the torque
in some places to get more in others etc.
Lightening moving parts is doubly beneficial. The wheels should
be the first step.
Joe
PS: Just for interest, mathematically, if a 3000 lb. car can put
down a constant 200hp to the ground for an entire quarter-mile
run, it's a 9-second car.
Old 03-08-2007, 10:45 PM
tom kerr's Avatar
Kevin,
go through the weight loss thread and pick what you like. there is an "easy" 150 pounds to shed.
Old 03-09-2007, 06:49 AM
silvershark's Avatar
silvershark is infamous around these parts
Originally Posted by tom kerr
Kevin,
We could all probably reduce our body fat % and = 5lb-15lb or more.
Just an idea...only in the name of health and speed
Old 03-09-2007, 10:21 AM
tom kerr's Avatar
That actually is very real and a great idea for all it may apply to.
I would rather (as an MD of course) see someone loose 10 pounds of unneeded weight rather than buy a lighter battery!!
I weight 160 compared to racing someone who weights 220, think about it me and my car are 60 pounds lighter!!!!
Old 03-09-2007, 08:15 PM
flatsixnut's Avatar
How about 2400 pounds and 220 hp? I think I can drop off another 200 pounds no problem. Guess that puts me at 10.9 pounds per hp.
So if I lost another 200 pounds, It would feel like I gained another 30 hp?
Old 03-09-2007, 08:23 PM
At that point, it's a rough 10.9 lbs per hp. Drop 200 lbs and it's like increasing 18 hp. It'll always be off a bit, especially as you make bigger weight or hp changes.
Again, as Joe Weinstein pointed out, these are only approximate numbers. There's more to the story.
Old 03-09-2007, 08:24 PM
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
I tell this to KPG all the time!!! Lay off those burgers!!
Quick Reply: Weight diet/ horsepower gains.
