H&R Sway Bars
Old 03-08-2007 | 04:26 AM
Turbo Fanatic's Avatar
H&R Sway Bars
Any opinions on these? I hear some people just do the rears.
I'm pretty happy with my Pss9s and custom alignment. Is this a worthwhile upgrade?
Old 03-08-2007 | 05:28 AM
silvershark's Avatar
silvershark is infamous around these parts
I will let you know as soon as I break in my Gaurd LSD (500 mile break in)
I have PSS9"s and just installed the H&R rear sway bar over the GT3 bar.
From what I have read on the posts, the rear is the way to go. Using the
center hole on the sway bar adjustment. I am told the damper setting can
be reduced to improve the ride and still increase the cornering. The H&R
is also supposed to reduce understeering. We shal see soon!
Old 03-08-2007 | 07:57 AM
ccayer's Avatar
ccayer is infamous around these parts
I have them and ran them in conjunction with H&R springs. Helped control the car and keep it flat. Ran them in the soft setting. It was an upgrade over stock bars and fitment was top notch. They are significantly more "beefy" than the stock noodle swaybars.
I run them now with Motons and love the suspension. I think they are a worthwhile upgrade. They keep the car just flat enough to make nice controlled slides
Old 03-08-2007 | 08:04 AM
amerlemans's Avatar
amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !
Dan at Vivid encouraged me to get just the rear H&R swaybar with my purchase of the JIC c/o system.
Old 03-08-2007 | 09:59 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
I have them front and rear with my jic set up. I love them If you buy the front use it on the middle setting and the rear on middle also. Seemed to work well for me.
-SM
Old 03-08-2007 | 11:21 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
i have the Gt3 ones, but i think the h&r ones are better since (designed for 4WD vs designed for 2WD)
Old 03-08-2007 | 02:24 PM
tom kerr's Avatar
the GT3 rear is all you need. OEM motorsport part cheaper and hollow. The H+R bar is ok as well and anything is better than stock.
Old 03-08-2007 | 02:51 PM
iLLM3's Avatar
I have the GT3 front/rear and it made a drastic difference in how the car felt
Old 03-08-2007 | 07:31 PM
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
do you NEED the drop links as well when you buy the GT3 and/or H&R sway bars??? or is it opptional???
Old 03-10-2007 | 05:05 PM
jstrat85's Avatar
jstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to all
do you like your jic c/o system? dan said that this is the best one out there!
Old 03-10-2007 | 05:09 PM
amerlemans's Avatar
Actually the jic is getting installed next week with the H&R swaybar and B&M short shifter. I'll certainly post back after driving it. I don't think I have heard even one negative comment about them.
Old 03-10-2007 | 07:15 PM
jstrat85's Avatar
so what do you guys think? buy the front and the rear or just the rear??? also how much did you guys pay for just the rear??? thank you
Old 03-10-2007 | 07:21 PM
WOODTSTER's Avatar
Rear only H&R from Sharkey or Dan @ Vivid.
I did my rear only with my Cross JIC and it improved turn-in.
Tends to oversteer at limit better also.
MK
Old 03-10-2007 | 07:22 PM
Chasen1211's Avatar
why not the fronts as well??? will it be a negative affect on the car's handling???
Old 03-10-2007 | 07:25 PM
WOODTSTER's Avatar
The downside to JIC is it tends to ride rough. I have mine set on Middle
position front and rear and it reminds me of the wild west when I go over
bumps (But man does it handle on the track!!!
I need to try softest setting for the street, I heard that works well.
MK
