MY NEW 60 to 130 mph in 5.15 SECONDS
#46
Originally Posted by MARKSKI
Thanks guys....... I have JIC suspension with solid subframe mounts and billet upper/lower control arms.
Thanks...I have the same suspension...can you PM me your specs to on your settings?
thanks!
#50
Originally Posted by houstonT
WOW, congrats, that is SICK! It'll be tough for any Supra's to beat that 60-130 time at TX2K7...
Peter
Peter
#52
The run is with 2 shifts as it should be to be comparable apples to apples to magazine tests which are the same , congratulations.
ACS-3, the one gear run is 4.96s. (posted above)
Do proper shifts and you are below 5 seconds. Boy you need to practice!
#54
Thanks guys for the kind words.... we are still battling the track to allow us run under 11.5 without a cage. Woodster was kind enough to lend a P car roll cage.. not sure they will react with a 4 point only... but at least its something.
I hope the axles hold up.
mark
mark
2001 996TT 3.6L and stock ECU
#56
Mark, nice to see someone with skill and appreciation for performancethat owns and drives a car like yours. I think that you have just scratched the surface with your performance so far. There are a lot of variables when dealing with a high HP car such as yours, the only way is up!!
CONGRATS!! Keep up the good work and keep us posted!
#57
mark
mark
Also 1) any car running in excess of 9.99 must have chassis inspected and certified by NHRA every 3 years and have the correct sticker affixed before running
2)Any car built after 1982 running irs or swing axel must have a 1 inch wide x1/4 inch thick axle retention loop on each axel
3)Any Porsche or VW engine car running faster that 11.49 that is FI must be equipped with a SFI spec steel flywheel shield from another application,minimum of 1/4 inch steel plate mounted to the engine block at all available bolt holes, extending a minium of 1 inch to the front and rear of the flywheel/clutch area.
And there is a bunch more, but I really hope you can make a few good passes and get that baby in the 9's.......
#58
Joe,
thanks for the support... I really appreciate it...
mark
mark
#59
Great numbers.... Now you can go hunting for the Exotics being very relaxed. Why not fish for some Enzo's, LP640's, Zonda's, McLaren's ...etc.
BTW, what's the Bugatti Veyron numbers for the 100-200 km run ?
Congrats Mark.
Congrats Mark.
#60
There is one Bugatti in chicago and my suspension installer SOl knows him....
maybe we can arrange something
