5 bar FPR install info
Old 05-11-2007 | 06:16 PM
andyk79's Avatar
andyk79 is infamous around these parts
Putting in the 5bar is a pain in the ****!!!
Old 05-11-2007 | 07:17 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Yes it is! I am having a hell of a time getting the pin in with the new one! Theres only room enough to get one hand in there.
Old 05-11-2007 | 08:28 PM
cajunairman's Avatar
cajunairman is infamous around these parts
The pin will push through only if the FPR is pushed in all the way. You'll barely have enough room to push the vacuum hose on when it's in all the way. Don't forget, just install the clip from the top too.
Old 05-12-2007 | 08:22 AM
andyk79's Avatar
If worse becomes to worst, just have a shop install it for you. Trust me itll save you time and the frustration.
Old 07-27-2008 | 01:14 PM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
I'm trying to get my 5bar FPR installed and I need some help guys... So is it located right under the air injection pump? Can you see it without removing the pump? Does anyone have pics on removing the air injection pump? Check out the pic below I found, my question is what did it take to see it? Thanks...
Old 07-27-2008 | 04:13 PM
oak's Avatar
oak
You will need to just unbolt the pump and move it aside. Once you move the pump you will see the fpr from the top. The view in the pics is not how it will look from the engine bay.
I used a large and long screw driver with the tip wedged into I believe was the engine mount and used the arm of the screw driver to push the top of the fpr and seat the fpr into the housing to install the clip from the top. When I orginally removed the clip to remove the old fpr it was install from the bottom.
hope this helps, did you try the search funtion?
Old 07-27-2008 | 04:59 PM
sid350's Avatar
Yes, I searched through the all threads and couldn't find any other pics. Thanks for the tip, I'll try it out and take some pics along the way.
Old 07-28-2008 | 04:32 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
installation
Guys...i am sure somowhere here there is a how to change fuel pressure regulator...when I wanted to get access to mine,i found directions...
Old 07-28-2008 | 05:14 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
"Mikelly"...
do a search. GREAT writeup w/ pics.
Old 07-28-2008 | 12:46 PM
ZIP22's Avatar
ZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond repute
https://www.6speedonline.com/forums/...oving-fpr.html
Old 07-29-2008 | 12:04 AM
sid350's Avatar
Got it! Thanks fellas!!
Old 07-29-2008 | 12:51 AM
Turbo Fanatic's Avatar
Do you guys think a 5 BAR FPR. 30+% more pressure taxes the fuel lines etc?
1.2 bar rolls of the tongue pretty easy, but it's like 18 PSI.
MadWhip
09-03-2015 02:04 PM
TrackOne
08-20-2015 12:56 PM
08-20-2015 12:17 PM
Nissan GTR
08-19-2015 02:11 PM
Quick Reply: 5 bar FPR install info
