Head work
Head work
Pulling my heads because I blew my HG.. I have a GT700 wondering if fellow 6speeders recommend I do some work on my heads and if so what do you recommend?? valves? larger? polishing? titanium?
Cheer
Robert
Cheer
Robert
I'm not sure who Stephen would recommend, but Greg Goode is one of the best head porters around.. Does Cyl heads for some of the fastest Outlaw 10.5, True 10.5, LS1, etc. in the country.
Unless Stephen and them have someone they use I'd look at someone like him or others that are of his caliber.
How Much Does Evoms Charge To Reprogram Thier Kits.. I Know Protomove Only Charges Around 350 To Reprogram Once You Purchased There Programing?? Also I Have Heard That Evoms Now Is Doing Greedy Boost Control As An Option.. I Would Love To Hear If This Is True
Cheers
Robert
Cheers
Robert
Once you are opening the engine, you should definitely install stronger rods, head studs and a head gasket, and possibly also stronger valve springs.
You should also port and polish your heads. EVOMS has a relationship with a shop that, form what I hear, does very good work. As others have observed, a new program will likely be necessary to accomodate the increased airflow. I suspect that EVOMS already has such a program available for GT700s with ported heads, but if they do not, they can create one for you.
Good luck,
Craig
Good luck,
Craig
ROb, were u running pump has at 1.4+ bars? I hope not cause that would be the #1 reason why u blew the head.
anyways,
sorry to hear.
mark
anyways,
sorry to hear.
mark
2001 996TT 3.6L and stock ECU
I don't know about "kits" that include everything you want, but EVOMS stocks and sells Carrillo rods, ARP head studs, a stronger head gasket, stronger valve springs, and various other internal engine components designed specifically for 996TTs. Its one stop shopping.
Craig
Craig
