Schroth or Sabelt
Originally Posted by John D II
Which is the better choice for a 6-point harness?
Pull up or pull down style - which is preferable?
Note: To be used with TE roll bar and GT3 seats.
Kevin,
Did you buy the Simpson again? Is it a hybrid design? Any pictures?
Thanks, Guys. Where is the best place to get these?
Thanks, Kevin.
Could you either post for the benefit of all or if you wish PM or email me with the specifics of what I will require to make all this work with the GT3 seat? As you know, this is a first for me - i.ie. harness, roll bar, seats, etc.
If you have the part numbers for each item required, that would be very helpful, as well...
PS - I was going to buy one of these - Is it necessary?
John, here are they BK part numbers from Northstar Motorsports...They may be cheaper elsewhere, but this is where I purchased them
http://northstarmotorsports.com/prod...productID/7730
http://northstarmotorsports.com/prod...productID/2141
The part numbers are BK R-9004 xtra Short Tunnel Side Mount and BK 9003 Outside Seat Mount .... I will post a pic of the belt clipped in to the seat when I get home Sunday...Kevin
BTW, you do need that part you posted...it is the bar that bolts under the seat that you attach your twin anti-sub straps to....
Thanks, Kevin.
I like the Schroth in the pull-down configuration, to answer your original question.
Thanks, Al.
When you install the outside harness mounting clip with the TE bolt - you can still leave the factory belt in place. Correct?
John, that is correct. To make things easier all the way around, what I did was to go to an automotive store and buy 2 grade 8 bolts, the size being 7/16 SAE fine thread (I think the pitch is 24) in a 3" length. This will make the installation easier for you. The roll bar isn't much fun to install. Place the OEM loop on the bolt, being sure to have it passed through the top hole of the GT3 seat, and my preference was to not put it through the lower lap hole. Snap the OEM belt in place and assure that you have no unwanted twist. As I recall, I put the OEM loop on first, and then the BK piece last. They just sandwich together at the head of the bolt. When you do it, it will make sense which goes first.
Al, what is the easiest way to install the bar and seats?
Having never done it before, I am thinking I would:
1) Remove stock seats
2) Position the TE bar in place
3) Remove rear OEM belts, bolt the two rear TE uprights almost fully tight with the OEM belt ends on the outside of the TE bar when replaced
4) Remove the front OEM bolt and belt
5) Install the GT3 seats
6) Run the OEM belts through the seat holes and fully secure the front TE bars with the OEM belts and BK brackets in place...
7) Return to fully tighten the rear uprights
8) Install harness
Is this close? What am I missing?
Thanks, again.
8) Install harness
Thanks, again.
8) Install harness
Thanks, again.
8) Install harness
Thanks, again.
It will also be helpful to have a HD ratcheting tie-down strap (Home Depot) to squeeze the front struts together as you install. There is quite a bit of compression required on a little plastic support piece underneath the side wall carpeting. You might want to remove that section of side wall carpeting and trim the plastic by a quarter of an inch, or so. You can try to compress that area with a rubber mallet but you run the risk of tearing your carpet. Ask me how I know.
A pry bar and a small block of wood might be helpful in case the final front strut hole doesn't line up just right. Mine didn't, and it took a combination of the ratchet to pull the front bar rearwards and the pry bar to move it upwards.
You must separate the GT3 seats from their tracks to get the anti-sub bar bolted in, and if you plan to use the same location that I did for your OEM bolt-up that would be a good time to remove the door side square-headed through bolt. It is the one that can serve as a place to attach the lap belt for your 6-point system. Once the seats are installed, you can't remove that bolt without once again removing and taking the seats apart. Ask me how I know.
Have fun
