test drove TT clicking clutch?
test drove a 2002 turbo with 28k yesterday. The clutch had a clicking sound to it, is that normal. also the tranny felt loose. To be honest I thought the car would have felt more refined, it reminded me of an 1989 turbo not a 2002. is this normal...???
Im in the hunt for a car
MT
MT
The clutch sounds like a blinker clicking when i depress it and yes its normal. As for the tranny, mine also felt sloppy and the shifter made noise while shifting. Turns out a piece in my shift linkage (I think a bushing) is broken so i purchased a short shift kit to fix the problem (its a common upgrade and people seem to love the feel afterwards).
mine is an o1 16K on it and yes there is a faint clicking when depressing (engine off and very quiet). had it since i picked it up with 12 miles on it. the shifting doesnt sound right though....
Ross
Ross
I have it in my '03 and was told by the shop that it is normal. You can hear mine but it is not as loud as a blinker signal.
I have the same click noise, not very loud. I think there is a safety-neutral switch that won't let you start the car unless the clutch is pressed to the floor. I would guess it is that switch being operated that makes the click noise.
The shifter, however, should not be loose at all.
at 28K miles it will be soon in for a new clutch.... depending on how hard the previous owner drove. usually they go after 35K if driver hard. I had 2 aftermarkets so far. the clicking is usually when u have a after market clutch.. I think its the throw out bearing... normal.
2001 996TT 3.6L and stock ECU
Apex Chase
03-28-2016 02:00 PM
