Modified OEM Muffler 996TT
Rating: Thread Rating: 2 votes, 5.00 average.
  #286
Old 04-06-2009, 02:28 PM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
Were the chewed blades on the compressor or the turbine side?
  #287
Old 04-06-2009, 02:39 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
cold....
  #288
Old 04-06-2009, 02:44 PM
I can't see how exhaust bits would get from the muffler into the intake track. Doesn't sound related to me.
  #289
Old 04-06-2009, 06:18 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Originally Posted by $manager
Hey guys...
Don't want to scare anyone off from doing this and I absolutely cannot prove anything BUT......I did this mod....then two months later changed my turbos out from stock 16's to the 24/18 deal and......one of my turbos had some blades chewed up.
Like I said, no way to prove anything as I couldn't find any debris.......I'm just sayin'.......
I cannot imagine this happening as the "debris" would have to get through the two cats on each side of the car that Porsche has between the turbo and the exhaust...and air/pressure is going the wrong way .....so very, very unlikely.
Not impossible. But I bet something else happened..
JB
  #290
Old 04-11-2009, 05:30 PM
raineycd's Avatar
Just did this to my car this weekend! Awesome sound! I expected it to be louder, but it was really nice. Much more rich of a sound and you can hear the turbos whistle better! Haven't driven it much to see if there is a noticeable performance difference.
I did the mod myself for less than $25 (I picked up a hole saw and arbor at my local Fastenal right next door to my office...). I just used a bi-metal hole saw with the drill bit taken out. Can get them from Lowes for under $15 (link below). I did 1 3/4" but can go bigger or smaller based on how much louder you want it. 1 3/4 was good, but I would probably want it a little louder...
Only problems I had was the saw got a little dull toward the end, so start both sides before you dull the blade. Basically, put the saw in and hold it against the wall of the pipe as you cut to get a consistent start. Once you break through the pipe on one side, do the other side before you dull the blade too much. Then just use very light pressure or the saw will snag and stop the drill. I had to reverse and go forward several times until I figured out very very light pressure - just let the saw do the work.
After several battery charges all was done! These saws have arbors that will fit into a socket. I put a drill to 1/4" socket converter in my chuck, then put my 10", 1/4" socket extension in then a proper size 1/4" socket to match the saw arbor. That got me more then enough room to get into the pipe.
So for less than $15, you can greatly enhance the sound of your car! Awesome Mod! Thanks to TJW and everyone else!
http://www.lowes.com/lowes/lkn?actio...8.0&lpage=none
  #291
Old 04-16-2009, 02:04 PM
Blue Monster's Avatar
Blue Monster is a jewel in the roughBlue Monster is a jewel in the roughBlue Monster is a jewel in the rough
OEM Muffler Mod
First off, thank you to all you who have started, added, and contributed to this thread. Special thanks to raineycd who helped answer my questions before I dived in over the past two days.
I am proud to say that I am the latest owner of the TJW Mod.
But, not without a few issues. I used a battery power drill with a Rigid 1 1/2 circular blade. Fortunately, I have several batteries. I started on the driver's side and ended going deeper on right side of the pipe than I planned for the first cut. However, this was more of a flat spot for the drill (mistake number #1). As I kept drilling the near side easily created a nice semicircular hole, but the far side was not getting the blade due to the angle. So I pushed forward (mistake #2). I eventually got a nice smoothed curved oval hole, but a thin crescent hole on the back of the muffler! For the passenger side I stayed more to the right and with more experience drilled a perfect curved oval quickly and easily. I was clearly concerned about the hole on the driver's side, but after a quick trip to the local Meineke it is all patched up.
As for the sound, awesome at the low end. A real rumble from 0 - 2500 rpm that is totally new and reminds of my best friend's Dad's Porsche from the early 80s. Not much of difference at higher rpm, but I think I can hear the Turbos much better now. I can't say for sure if there is any noticeable power difference, but other than a quick trip to the muffler shop I got exactly what I wanted for $50.
So, thank you again and appreciate the DIY.
--BM
  #292
Old 04-16-2009, 02:10 PM
raineycd's Avatar
--BM
Awesome job! Yeah, my holes are egg shaped due to the curve of the pipe. Love the sound! Especially at 3000 - 3500 rpm - gets that nice exotic growl!
  #293
Old 04-16-2009, 10:01 PM
vip gts's Avatar
vip gts is just really nicevip gts is just really nicevip gts is just really nicevip gts is just really nicevip gts is just really nice
I did this last week with the ridgid 1.5 inch hole saw with the center bit taken out.
I used a plastic PVC pipe that fit in the tail pipe and and wood shims to hold it in place. The hole saw fit perfectly in the center and this kept the saw straight and made it very easy, it actually cut through like butter so I went slow at the end and then just used pliers to pull the last part off.
The sound is better, slightly louder at idle but similar at wot. I am currently awaiting my speedtech 60mm but I got bored so did this.
  #294
Old 04-18-2009, 01:06 AM
BMo's Avatar
BMo
BMo is offline
BMo is infamous around these parts
Dudes! What an awesome thread. I just read it all in one sitting (I had my knee scoped today so I've been doing a lot of reading). I've been seriously trying to figure out how to get an aftermarket exhaust on my car but this will achieve 75% of what I want for the fraction of the cost. I'm emailing my mechanic tomorrow to get the TJW done. Thanks to all!!
  #295
Old 04-20-2009, 07:02 PM
CarreraMark's Avatar
CarreraMark is infamous around these parts
I was just getting ready to pull the trigger on a Europipe Stage 1. Given the low cost of trying this out, i am planning on trying it first. Wouldn't mind hearing one first but thats the price I pay for living in western kentucky! Thanks for all of the information!
  #296
Old 04-20-2009, 11:00 PM
Search on youtube for jcbmemphis....
the J in the mod...
  #297
Old 05-26-2009, 02:01 AM
kc2ab's Avatar
kc2ab is infamous around these parts
do you still have ur x50 exhaust?
jimR
so calif
03 x50 tip
jjrho@roadrunner.com
(didn't think it would just post at the end....was trying to reply to someone with a modified x50 exhaust for sale, one with baffles taken out, on page 6 or 8 or somewhere there.... )
Last edited by kc2ab; 05-26-2009 at 02:03 AM. Reason: too vague, to whom it's addressed....
  #298
Old 05-26-2009, 07:34 AM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
+1 on the 100 cell cat mod here. Took me about 4 hours total. My butt-dyno wasn't calibrated, so I have no clue on the gains.
My next step will be to work on the internal baffling. Does anyone have a higher resolution photo of the internals of this muffler?
  #299
Old 05-26-2009, 09:10 AM
oak's Avatar
oak
oak is offline
I have a stock exhaust take-off w/ only a few hundred miles on it.
If anyone is interested. not an x-50 but it's moot if you are going to drill it...
  #300
Old 06-01-2009, 01:58 AM
kc2ab's Avatar
drilling difficulty
well, got a 1/2 inch metal drill bit that's about 16" long at lowes, and i tried to drill but the drill bit wouldn't bite...couldn't get started.... bit end wandering all over the place....
i was thinking of drilling 2 1/2" holes...at 1/2 " increments....
i like the idea of using a ship/pvc pipe, etc..
oh, and i WD40ed the bolt and couldn't loosen the twin tip of the exh pipe either....
any other suggestions on getting this done at home?
brought the car to a garage locally and couldn't drive on the ramp... too sharp of an angle for the car....
jim R
03 x50 twin tip stock exh - needs some holes put in....
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Modified OEM Muffler 996TT
