Modified OEM Muffler 996TT
Rating: Thread Rating: 2 votes, 5.00 average.
  #301
Old 06-01-2009, 04:58 AM
raineycd's Avatar
Originally Posted by kc2ab
well, got a 1/2 inch metal drill bit that's about 16" long at lowes, and i tried to drill but the drill bit wouldn't bite...couldn't get started.... bit end wandering all over the place....
i was thinking of drilling 2 1/2" holes...at 1/2 " increments....
i like the idea of using a ship/pvc pipe, etc..
oh, and i WD40ed the bolt and couldn't loosen the twin tip of the exh pipe either....
any other suggestions on getting this done at home?
brought the car to a garage locally and couldn't drive on the ramp... too sharp of an angle for the car....
jim R
03 x50 twin tip stock exh - needs some holes put in....
Probably will have to do a pilot hole with a smaller bit first to get the larger one to get a bite. It is somewhat of a challenge to get any bits started on the curved part. Smaller, very sharp bit will be much easier to get started. Or use a center punch and put a dimple in it if you have one.
Oh, and drilling multiple holes (starting at 1/2 inch and doing 1 inch then 1.5 inch) - be sure you have a plan to get them all started. I think it may be hard to get another one started if you have a hole already...
  #302
Old 06-01-2009, 05:46 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Anyone in the DC area that has done this? If so please PM me so I can get a listen to the end product.
  #303
Old 06-02-2009, 12:46 AM
sleepys4's Avatar
sleepys4 is infamous around these parts
This is not a bad idea, I may try this.
  #304
Old 06-02-2009, 08:17 PM
Blue Monster's Avatar
Blue Monster is a jewel in the roughBlue Monster is a jewel in the roughBlue Monster is a jewel in the rough
jim R
I had the same problem to start, if you are using the drill you need to use very high rpms with very light pressure and it will cut through in a couple of minutes.
  #305
Old 06-02-2009, 08:38 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I think that if you guys are looking for a truely unique and exotic sound the whistle tips are the only way to go.
[media]http://www.youtube.com/watch?v=ccgXjA2BLEY
  #306
Old 06-02-2009, 10:01 PM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
That's a good way to ruin a bit. If you're only doing one muffler and trashing the bit, it's fine. High speed with light pressure and metal drilling generally doesn't do much for too life without lots and lots of cooling. A dimple or smaller bit for a pilot hole would be a better solution.
  #307
Old 06-03-2009, 12:43 PM
I would listen to Brad, this was my first time drilling metal with a battery powered drill, I tried with a setting too low and it just would not cut well
  #308
Old 06-03-2009, 12:50 PM
It's optional to listen to either one of us really. One just has to ask themselves if if they are going to use the bit once or try and use it for other projects. I've been guilty of "one use bits" myself. At least until I ruined a couple of expensive bits.
  #309
Old 06-03-2009, 03:38 PM
Webtool1's Avatar
Webtool1 is infamous around these partsWebtool1 is infamous around these parts
I'm pretty sure my shop teacher told us slow, heavy and wet was the way to cut/drill stainless. That was at least a hundred years ago but I'll bet nothing much has changed.
  #310
Old 06-04-2009, 04:04 AM
ScottKelly911's Avatar
ScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond repute
Slow, heavy and wet? You sure he wasn't talking about his wife
  #311
Old 06-04-2009, 05:00 AM
Gunther's Avatar
So there is no one in the DC area that has done this mod
  #312
Old 06-05-2009, 03:58 PM
g8rdmd's Avatar
g8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to behold
I'm the latest to join the TJW Mod Club Had the day off today, so I decided to stop reading about it and just do it
Took off my tips so I didn't scratch them, and bored a hole right through the pipe! It takes a little effort to get the initial pilot hole through the steel (yeah, Porsche doesn't skimp on their materials), but once in it was easy to open it up. I stopped at about 1 1/8" for now...the sound is definitely noticeable in a good way A nice, louder and deeper growl than before. I haven't had much of a chance to drive yet, so I can't say anything toward power yet.... All-in-all, a cheap, easy and awesome mod
  #313
Old 07-03-2009, 12:18 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
I started with 1/2" holes a few months ago and finally had them opened up to 2" yesterday. Made another huge improvement on sound and appears to spool faster. You can also test the turbos now!
This is the best DIY out there and such cheap entertainment. What a compliment for my EPL tune. Can't imagine what a realbe haust would be like.
  #314
Old 07-03-2009, 12:21 AM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Buy a hole saw 2" with the bit in the center or without FOR METAL, get a small extension on your drill, the 2" hole saw actually holds itself perfectly at the bend and does work! You will have 2 perfect sized holes when done.
Tips: Dont use cordless drill unless you have extra batteries laying around
  #315
Old 07-03-2009, 08:47 AM
drh's Avatar
drh
drh is offline
drh has a spectacular aura aboutdrh has a spectacular aura aboutdrh has a spectacular aura about
You'd have to have a long pilot bit in the hole saw to get the pilot hole going in the bend, then the dangerous part would be once you got the hole saw going, the pilot bit would penetrate the back side of the exhaust. This is the reason I went with the unitbit and extension rod.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Modified OEM Muffler 996TT
