Which oil provides the best protection? You might be surprised to find out...
In a nutshell:
A magazine conducted a very interesting test. They compared the maximum loads -in lbs- that 18 different brand name synthetic and semi-synthetic oils could withstand before braking down. The data of the test demonstrates long term wear in a very short period of time.
The results? Royal Purple, Penrite and Valvoline did the best.
Mobile 1 and Redline were among the worst.
I wish they would've tested Amsoil.
http://www.animegame.com/cars/Oil%20Tests.pdf
Thats why I have been using Valvoline VR1 racing in my engine
markski
markski
2001 996TT 3.6L and stock ECU
From the looks of the test, RP might be the way to go. RP R51 (now called XPR 20W-50) has a pressure resistance of 295,000+ psi. The Valvoline Durablend is only 23,000 psi. Not sure what the VR1 is...but I can't imagine it's as high as the RP. The RP XPR is very expensive, though. Around $13.00 per quart.
VR-1 racing Valvoline is what we run.... 20-50 ... Todd really likes it... something about an agent that protects the engine.... most others oils do not have that agent... not even the synthetic. I forgot what it's called.
The results I find most disturbing are those for Mobile-1 and Redline. Many, many people use those oils in their cars.
OK, I'll bite...and play devil's advocate...first the way the samples were taken can hardly be described as representative samples, second I saw no report on the measurement system uncertainty or precision. The article does not discuss if any test with the same lubricant was repeated. Third, unforunately the test was described as an accelerated life test, but using what reliability model for the test was not discussed (so does this have any relationship with reality)? I also don't care if it is the accepted test as I know many FDA, FAA, DoD, etc. measurement systems that are accepted and are random number generators. Of course they do mention that the test is only evaluating one characteristic...there are others important for our cars...like ability to cool or transfer heat energy.
Scott this is by no means an attack on you and I do thank you for posting...I guess that's what makes these forums informative.
F1 and Indy engines....
Back in the late 90's when I was working in the UK for Ford Cosworth the only engine oil used in either F1 or Indy engines was Mobil 1 full synthetic (can't recall the weight).
A lot of testing, analysis & research was carried out before Mobil 1 was selected for the F1 V10 engine revving to 18,000 rpm plus or the turbo charged Indy V8 revving to 13,000 rpm.
Maybe oil technology has moved on a bit since then and other brands might be better - but I'm sticking with tried and tested Mobil 1 :-)
Wross - I'm not a statistician. But I can sure tell a 1 inch sqaure gash in metal from a 1 cm square one. Thanks, though.
IRT to Mobile-1; the previous owner used to run it in my car before I purchased it. I changed the oil as soon as I got the car, but was still using the same viscosity Mobile-1 that he had been using. I was tracking my oil usage meticulously, and noticed that I was burning about a quart ever 1k miles or so. As soon as I switched to Amsoil, that number was cut in half. I burned less than a half a quart of Amsoil 5W-40 in the next 1k miles. Just my 2 cents.
I thought it was pretty common knowledge that Mobil1 was barely better than dino oil?
at any rate, REDLINE is great IF used in the right application... due to the high lead content (and a few other additives I can't recall) it's a very good high force lubricant. As in gear/tranny lube.
Very interesting comparison none the less, and yes I wish they would have tested amsoil as well.
Shocked MOTUL didn't do well in their tests, but has been pretty well proven as an excellent oil that holds up very very very well in extremely harsh condition. Makes me think there is more to it than just purely a pressure braking point.
I only specifically comment on the Motul because i've used it in bikes and such before and they look amazing when you're doing rebuilds. Maybe it's just sponsor $$$, but thats pretty much all Ducati recommends to be run in their bikes as well.
That test only measures extreme pressure steel on steel. It may apply to cam wear in a flat tappett American V8 with extremely strong valve springs. It doesn't measure oxidation stability, detergency, deposit formation on the turbo, rings, and combustion chamber, viscosity stability, acid neutralization capacity, evaporation, anti foaming, etc.
there is so much more that goes into a quality oil.
www.bobistheoilguy.com (or BITOG) for all things oil.
Hey, does anyone here run Used Oil Analyses when they change oil so see what YOUR oil is doing in YOUR car based on how YOU drive????
Roughtly $40-50 for the test and expert analysis... I swear by it in my M5. Haven't seen it mentioned here.
A
I've always had the best luck with Castrol.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
