Anyone else's TT "whistle" at idle after coming to a stop?
Just wondering, the Turbo ('04 cab) whistles upon coming to a stop. It can also be replicated most of the time by being held a certain rpm (~3k) for a few seconds. The noice goes away as soon as the clutch it pushed in. Any ideas? Thanks.
-Joe
-Joe
Sounds like the check valve or the pressure control valve on the hydraulic resevoir. A simple test is the following. Pop open your engine cover. In neutral rev the engine up to about 3k-4k rpm for approx. 30 sec. Release the accelerator and listen to the engine compartment. If you hear a whining/whistling noise (should be amplified from normal driving) that's your problem. Hope this helps.
i used to hear a whining sound, especially if i would drive in a close parking lot. It defntly has to do with the hydraulic resevoir.
I had the issue. If you push the clutch in, the sound should stop. They'll fix it under warranty. Mine used to do it at the track and I thought I was loosing turbos ... really high pitched whine.
